i have a Problem with my GL.iNet GL-MT300N-V Mango router.
It is connected to my home network as a wireguard server.
If i’m connected to the wireguard vpn, i can login to the web panel.
If i’m not connected to the vpn its not possible to access the webpanel at the moment. So i want to use the remote login.
The ddns works fine but the login window is my problem. I don’t know the username.
I’ve allready tried admin, root or the username from my vpn. But i cant login.
Can you give me a tip where I can set the username?
with kind regards,
Lling
