Hi there,
I’m getting this when calling /api/repeater/info
{msg: "sta not configed properly", code: -108}
When trying to call /api/repeater/enable
# trying to set it up with /api/repeater/enable?ssid=SampleConn&enable=true
{msg: “ssid check failed”, code: -99}
And finally, when I’m trying to connect to a wifi via /api/repeater/join with params as follows:
# parameters to /api/repeater/join
ssid: neo
mac: B4:6A:AF:C5:A8:40
encrypt: psk2
issaved: true
channel: 3
device: mt7628
caps: UNKOW
save2uci: false
I’m just getting 500 error. May be that is because I didn’t specify the WiFi password, but I don’t really know what field to use to do such.
Is there something that I’m missing to do prior to use that calls? Or is there any other mistake? Any help would be really appreciated.
API version: https://dev.gl-inet.com/router-api/2
Custom firmware version 3.336
Thanks!
