Hi Guy's , I want to add wifi to a remote ethernet only camera using the ar300 downstream from the main router.I have the ar300 connected to the main router ok as I have internet access. The ar300 UI shows the camera as client 186.192.8.13 and the main router show's the ar300 as 186.192.1.4. Using extend mode I can not see the camera on the main router via my CMS software which can find other wifi camera's connected directly to the main router. I've updated the firmware to the latest version. I only have a basic network understanding so I'm a little out of my depth.
Regards, Guzzi
If you want to access the camera connected to AR300M from the main router, it requires the AR300M and the connected its camera are in the same subnet as the main router.
Please check your network configuration of the AR300M, confirm is it in extender mode?
If in the extender mode, the IP of the camera connected to AR300M is supposed to be main router subnet: 192.168.1.x
