I saw the article to be able to connect the fiber directly to the router but i am not sure how to move from the fiber optic cable to the ethernet one, does any one have some documentation in regards to it.
but what termial? i saw online some fiber to ether media converters but not sure if they are going to work. Is that what you mean with connect to your terminal?
This goes to ISP router and i get ether cable from there but i recently got hacked cuz i cant setup any rules on that router. I would like to handle the traffic from your device.
Thank you very much, i can see they are not that expensive seen you as a security analyst do you have any advice when it comes to ONT, or i should be fine with any as long i have a good security on the AX1800
if the fiber goes straight inside your isp provided router it means that router is also a GPON device so you will need to set that one in bridge mode and run the ethernet cable from a LAN port of ISP router to WAN port of GL.iNet router
