Hello:
I wanted to use GL-AR750 as a file server to share files between my laptop and my wife’s laptop to share critical files stored in an 128GB SD card inserted into the SD card slot of GL-AR750.
I also would like to use it in WISP mode using wired connection to share the WIFI from the hotel.
Since we would be using the wired connection between the Laptops and GL-AR750, can we shut down the wireless broadcast of GL-AR750 for additional security even though GL-AR750 will need to connect to the hotel WIFI to provide WISP to the laptops?
Here is the configuration I have in mind:
Hotel WIFI <—Wireless—>GL-AR750 [with 128GB SD Card] (1) <—WIRED–>Laptop-1 (2) <–Wired–>Laptop-2
alzhao,
Thanks. I will check out the documentation.
I am new to this, so it looks like I need to learn a lot more to make it work.
For example when you say “disable AP”, I have no idea what “AP” means.
Let me read the documentation once I am able to find the “docs for repeater” you mentioned.
Thanks
