GL-MT300N-V2 as a VPN router just for a specific Wifi/SSID
hello, was hoping someone could help me - in brief, I would like to make sure that a specific Wifi/SSID gets routed to my GL-MT300N-V2 (firmware 3.216), which is then connected to a VPN. use case is specific devices in my network being connected to such Wifi/SSID so that they can access content from other countries/to get around geo-blocks. the other wifi/SSIDs should continue to be used as before ie not be connected to this VPN.
in brief:
- GL-MT300N-V2 is in router mode and currently works with no issue, I can connect to the VPN - when it has Wifi activated then this works as intended/described
- however, I would rather want the access points i have throughout the house to be used for the Wifi element instead of the Wifi of the GL-MT300N-V2
setup:
access points with Wifi -> connected via LAN cable to -> main router (draytek vigor 2866) (which is the device used for internet access and has other devices connected to it which are not to use the VPN set-up) -> connected via LAN cable (port 2) to the GL-MT300N-V2
Access points with the 'VPN' Wifi are tagged with VLAN2.
before I go into detail/a rabbit hole as to what the current setup is (which doesn't work and involves a static route, assigning a static IP etc as I can't seem to get DHCP to work on the GL-MT300N-V2, also it being on a different subnet (as I understand it) then the main router, dedicating port 2 on the main router as the port that the GL-MT300N-V2 should be connected to (and which then doesn't get recognised - on other ports it does with it's dedicated IP), would be grateful for any tips as to what the setup should be, keeping this as simple as possible?
