Can I assign the MT3000 a dhcp address and use it as a backup adguard home dns server when at home?
And as a travel router when away from the house?
I have 2 adguard home dns servers in docker on my NASbut if my nas goes down, they both go down, so I am looking for another device to run adguard home on when at home.
I would let run AGH on a device that does not go down - speaking, a router, not a NAS. In that case, I would set it as my default DNS and make sure that it will get distributed by DHCP to my clients.
When I am with my travel router exact the same thing will happen, so AGH will work fine since it runs on my travel router itself.
Running 2 AGH instances on the same NAS does not make any sense - what’s the goal here?
I completely agree with you re running 2 instances on the same NAS, not ideal. Which is why I want another instance on separate hardware. DNS 1 and 2 are the macvlan addresses of teh 2 ADH instances running on the NAS currently.
I tried installing AdGuard Home on my old ER5POE, but the HW was not up to the job. I don’t want to buy a Nuc or Pi just for this purpose and can see some distinct benefits of a travel router. I would set this instance of ADH as DNS3 on my DHCP scope.
My Internet is connected through a UDM which I don’t want to install ADH on as it will be wiped when upgraded.
My router is home.
2 phones for outside network (4G/5G)
Travel router is holiday things with small GL router.
Everything list filter in one DNS server.
So is this just using adguard DNS rather than running adguard home?
I like the ability to be quite granular with the block and allows, as well as using DNS rewrites and am not sure the DNS only service can do this.
I do use quad9 and adguard DNS as upstream.
I suppose I am looking to convince myself to buy a travel router and one way to persuade myself is if I can use it as an adguard home server at home, using my ud se for internet and DHCP.
I then have the benefit of being able to take it with me when I travel or am away from home.
