greetings all i have recently purchased two ax1800's in hopes of putting the expressvpn firmware on them so that i have a cheaper aircove router (i have not succeeded at this venture but thats for another time).
so far heres what i have
-starlink setup with the router disabled.
-ax1800 with starlink cable plugged into the wan port
-a few other ethernet things on the other ports. one of which is an ethernet cable that goes to my garage. another is a eufy homebase for my camera setup
the ethernet cable going to the garage WAS plugged into a google nest setup so i know it is good and works. when i try to use the garage ax1800 both routers stop working, almost as if i have changed them both to wifi repeater or access point (i have tried it both ways with no success)
what am i doing wrong? do these routers work like i want or should i return the garage ax1800 and get one of those travel axt1800's?
