I am reverting from my AR750 to my AR300M after constant disconnects since the latest v2 update I have given up. I tried updating my AR300M with the testing v3 beta but for both the .bin files it says incorrect firmware. Can admin double check its correct. thank you.
The v3 firmware is for Nor flash.
We will push for a nand version ASAP.
Nand firmware is available in http://download.gl-inet.com.s3.amazonaws.com/firmware/ar300m/testing/gl-ar300m_nand-3.003-0925.tar.
I know it’s only beta but having given that firmware a quick whirl, it needs a lot of work still!
Put all the bugs in the v3 bugs thread ![]()
