AR750 V3.x, How to change hostname ?
I know, i asked in the past the same question. A I dont find the answer again.
I remeber, its possible to change the hostname (which is repoted to DHCP) on advanced admin menue.
Thanks
Thanks
Luci > System > System.> General Settings - is that what you’re looking for?
G
Thanks for your answer. Thats was i am looking for.
Now i have found two additional other places, which sounds like “Changing hostname”. I dont know what the different. Now I will check the follow:
Yes, this is the correct place for hostname reported via DHCP to upstream routers.
Change hostname via cli
uci set system.@system[0].hostname=‘your-hostname’
uci commit system
/etc/init.d/system restart
alzhao It is correct?
Actually I don’t know if this is correct. Seems dnsmasq has other settings about hostname.
change hostname from luci gui, working normal, but interesting change from cli
Deleted. Was doubled.
