V4.6.3-op24 Details?
Can we get some info on what fixes have been merged into the op24 version is it “current” on commits as of build date ?
Should be shown on the changelog website:
That isn’t what I am asking for that’s the generic 4.6.3 I want to know what fixes from the Open source driver updates that have been added.
I mean, that's what all we know, if you need deeper details I suggest to check the source code :call_me_hand:
Just looking for the same change log details they used to post when all the snapshots where posted. After that firmware mess I figured details on changes would have been seen as important. Captain Obvious replies aren’t helpful from the standard few
Wireguard home vpn dns timeout but works with commercial wireguard config.
Both profiles works with non op24 v4.6.3, what am I doing wrong.
I'd agree, they could add a 'full update notes' button and then fetch the github commits.
Well... they probably still need to filter with a regex, but for example when OpenWrt merges mt76 commit often starts with mt76: prefix, often if you expand the commit it has the usefull text.
Its probably alot of work, but definitely usefull.
