Variable bitrate. Is it possible?
It seems like the comet uses constant bitrate to stream the video feed. This not optimal when I need high or ultra-high, but really it's just non-moving things like text. Trying to look through htop via the comet without using high or ultra-high or high is almost impossible. It's all blurry. This can simply be resolved by sending a variable bitrate stream. Is this a limitation of the hardware itself or a software issue? The encoders on this soc should be able to handle it fine. If I try looking at a console during htop on high, it uses 6-8 megabits per second! Something like this over h264 will be totally fine at a megabit per second. The bitrate requirements on the comet seem excessive.
Wonder if the hardware is there to transcode?
This can be achieved through software updates, but it will take some time
