Velica B2200 drop-in gateway?
Can the Velica be configured as a drop in gateway?
Got an elderly relative with ADSL, sky UK broadband, needs to keep sky router.
So I need to disable DHCP on the sky router, drop the Velica in.
Mesh the second Velica to replace the rubbish repeater.
So is it possible as I want to replace the Opal I have deployed with something that supports AGH and can create a mesh network for them.
If the Sky router can be configured as bridge mode, I don't see any problem to make the Velica the main gateway of the home connected to the carrier's router/ONT. Simply connect the first Velica to the Sky router, and configure the second Velica in Repeater Mode. Velica also supports mesh router mode, so it couldn't make any problem.
