Verizon home 5g on GL-X3000
Hi all,
Im getting conflicting information on if the GL-X3000 can support Verizon home 5g internet. It would be better for me to stick with Verizon due to being with visible cellular for my phone.
Can anyone clarify if it is or isn't supported, and if there are additional steps needed to set it up to work?
Thanks.
The Verzion SIM card may be available on X3000, since some users have reported that they can connect with the Verizon SIM without configuring anything.
Of course, there are also a small number of users who say that Verizon cannot be connected, including fill in the APN, either.
For users who would like to use GL X3000, we recommend that you test it to confirm.
We can also listen to other users voice.
