I purchased a GL.iNet Flint2 router. It just arrived today.
I configured it, and installed it, replacing my old TP-Link Archer C2300. Now, my issue is that the transfer speeds of the new router are about half of what I got on the old one, both on WiFi (5 GHz) and via ethernet.
The setup is as follows:
the ISP device is in passthrough mode and internet traffic just flows through it
a Cat6 ethernet patch cable connects the ISP device to the WAN port of the Flint2 router
I have a Raspberry Pi server connected directly to the Flint 2 router, in a 1Gbps ethernet port
another ethernet cable (Cat 5e) connects a 1Gbps port of the Filnt 2 to an ethernet wall outlet
the wall outlet connects to a switch in my office, and, also to the switch, I have connected my home server (via Cat 5e)
I got two computers connected via WiFi 5Ghz, which are the largest consumers
there are also other computers and various appliances, a TV, a vacuum cleaner, etc.
The Filnt 2 router is inside a plastic cabinet, in the exact middle of the home, close to the ISP device.
The problems are as follows:
I can’t seem to get wifi speeds higher than 200-250 Mbps, via Wifi 5GHz; with the previous router I always had a speed of a minimum of 300 Mbps, with the average being around 400-450 Mbps
the home server used to get close to 1 Gbps transfer speed, and now it has a max of 400 Mbps, only in some cases, but most of the time it’s around 300-350
While I could, theoretically explain wifi speeds (weaker signal maybe), I can’t however, find a plausible reason why the speed over ethernet has lowered so drastically. Please keep in mind that the router I was using previously (and it’s quite old), was sitting in the same place as the new one, but had more than double the speed. I was expecting to get at least marginally higher speeds with the Flint 2.
For context, the devices I’m testing it on are a 2017 iMac (AC WiFi) and an M1Pro MacBook Pro (AX WiFi).
I guess that I might be missing something while configuring the router. Since I kinda like it a lot and would not want to send it back, please give me a hand in tuning the settings to obtain the desired result.
Thank you in advance!
