Hello, I recently upgraded to firmware v4.1 on my GL-AXT1800. Since then the wifi network has been very unstable.
I’m in wifi-repeater mode. Connected to a 5G Wifi network in repeater mode, and creating my own 2G and 5G wifi networks. It starts out OK, and I get very good download speeds on my clients. Every minute or two the light on the front of the router starts blinking. Sometimes the internal 2G and 5G networks disappear then after a minute reappear, but not always. Once I manage to reconnect to the internal 2G or 5G network (sometimes takes a couple of trys, all is well again for a little bit.
Below is my log from just before a disconnect, then it goes down, then comes back up.
Sat Jan 7 15:03:23 2023 daemon.notice hostapd: wlan0-1: AP-STA-DISCONNECTED dc:a6:32:f9:83:eb 0 0
Sat Jan 7 15:03:23 2023 daemon.info hostapd: wlan0-1: STA dc:a6:32:f9:83:eb IEEE 802.11: authenticated
Sat Jan 7 15:03:23 2023 daemon.info hostapd: wlan0-1: STA dc:a6:32:f9:83:eb IEEE 802.11: associated (aid 4)
Sat Jan 7 15:03:23 2023 daemon.notice hostapd: wlan0-1: AP-STA-CONNECTED dc:a6:32:f9:83:eb 0 0
Sat Jan 7 15:03:23 2023 daemon.info hostapd: wlan0-1: STA dc:a6:32:f9:83:eb RADIUS: starting accounting session 077F77E64B5F66F5
Sat Jan 7 15:03:23 2023 daemon.info hostapd: wlan0-1: STA dc:a6:32:f9:83:eb WPA: pairwise key handshake completed (RSN)
Sat Jan 7 15:03:23 2023 daemon.info dnsmasq-dhcp[5810]: DHCPREQUEST(br-lan) 192.168.8.131 dc:a6:32:f9:83:eb
Sat Jan 7 15:03:23 2023 daemon.info dnsmasq-dhcp[5810]: DHCPACK(br-lan) 192.168.8.131 dc:a6:32:f9:83:eb raspberrypi
Sat Jan 7 15:03:57 2023 daemon.notice netifd: Network device 'wlan-sta0' link is down
Sat Jan 7 15:03:57 2023 daemon.notice netifd: Interface 'wwan' has link connectivity loss
Sat Jan 7 15:03:57 2023 kern.info kernel: [ 172.392444] wlan-sta0: disassociated from e0:63:da:19:87:a7 (Reason: 1=UNSPECIFIED)
Sat Jan 7 15:03:57 2023 daemon.notice netifd: wwan (8943): udhcpc: received SIGTERM
Sat Jan 7 15:03:57 2023 daemon.notice netifd: wwan (8943): udhcpc: unicasting a release of 172.16.130.197 to 172.16.130.1
Sat Jan 7 15:03:57 2023 daemon.notice netifd: wwan (8943): udhcpc: sending release
Sat Jan 7 15:03:57 2023 daemon.notice netifd: wwan (8943): udhcpc: entering released state
Sat Jan 7 15:03:57 2023 daemon.notice netifd: wwan (8943): Command failed: Permission denied
Sat Jan 7 15:03:57 2023 daemon.notice netifd: Interface 'wwan' is now down
Sat Jan 7 15:03:57 2023 daemon.info avahi-daemon[3439]: Withdrawing address record for 172.16.130.197 on wlan-sta0.
Sat Jan 7 15:03:57 2023 daemon.info avahi-daemon[3439]: Leaving mDNS multicast group on interface wlan-sta0.IPv4 with address 172.16.130.197.
Sat Jan 7 15:03:57 2023 daemon.info avahi-daemon[3439]: Interface wlan-sta0.IPv4 no longer relevant for mDNS.
Sat Jan 7 15:03:57 2023 daemon.notice netifd: Interface 'wwan' is disabled
Sat Jan 7 15:03:57 2023 daemon.notice netifd: Interface 'wwan' is enabled
Sat Jan 7 15:03:57 2023 daemon.warn dnsmasq[5810]: no servers found in /tmp/resolv.conf.d/resolv.conf.auto, will retry
Sat Jan 7 15:03:57 2023 daemon.notice wpa_supplicant[2479]: wlan-sta0: CTRL-EVENT-DISCONNECTED bssid=e0:63:da:19:87:a7 reason=1
Sat Jan 7 15:03:57 2023 daemon.notice wpa_supplicant[2479]: BSSID e0:63:da:19:87:a7 ignore list count incremented to 2, ignoring for 10 seconds
Sat Jan 7 15:03:57 2023 daemon.info repeater: (/usr/sbin/repeater:472) IFNAME=wlan-sta0 <3>CTRL-EVENT-DISCONNECTED bssid=e0:63:da:19:87:a7 reason=1
Sat Jan 7 15:03:57 2023 user.notice mwan3[13477]: Execute ifdown event on interface wwan (unknown)
Sat Jan 7 15:03:57 2023 user.info mwan3track[9577]: Detect ifdown event on interface wwan (wlan-sta0)
Sat Jan 7 15:03:57 2023 user.notice mwan3track[9577]: Interface wwan (wlan-sta0) is offline
Sat Jan 7 15:03:57 2023 daemon.info repeater: (/usr/sbin/repeater:472) IFNAME=wlan-sta0 <3>CTRL-EVENT-SCAN-STARTED
Sat Jan 7 15:03:57 2023 daemon.notice hostapd: handle_probe_req: send failed
Sat Jan 7 15:03:57 2023 daemon.info repeater: (/usr/sbin/repeater:472) IFNAME=wlan-sta0 <3>CTRL-EVENT-SCAN-RESULTS
Sat Jan 7 15:03:57 2023 daemon.info repeater: (/usr/sbin/repeater:472) IFNAME=wlan-sta0 <3>WPS-AP-AVAILABLE
Sat Jan 7 15:03:57 2023 daemon.notice wpa_supplicant[2479]: wlan-sta0: SME: Trying to authenticate with e0:63:da:19:87:a7 (SSID='INVITADOS' freq=5200 MHz)
Sat Jan 7 15:03:57 2023 daemon.info repeater: (/usr/sbin/repeater:472) IFNAME=wlan-sta0 <3>SME: Trying to authenticate with e0:63:da:19:87:a7 (SSID='INVITADOS' freq=5200 MHz)
Sat Jan 7 15:03:57 2023 kern.info kernel: [ 172.968617] wlan-sta0: authenticate with e0:63:da:19:87:a7
Sat Jan 7 15:03:57 2023 daemon.notice wpa_supplicant[2479]: wlan-sta0: Trying to associate with e0:63:da:19:87:a7 (SSID='INVITADOS' freq=5200 MHz)
Sat Jan 7 15:03:57 2023 daemon.info repeater: (/usr/sbin/repeater:472) IFNAME=wlan-sta0 <3>Trying to associate with e0:63:da:19:87:a7 (SSID='INVITADOS' freq=5200 MHz)
Sat Jan 7 15:03:57 2023 kern.info kernel: [ 173.061781] wlan-sta0: send auth to e0:63:da:19:87:a7 (try 1/3)
Sat Jan 7 15:03:57 2023 kern.info kernel: [ 173.067628] wlan-sta0: authenticated
Sat Jan 7 15:03:57 2023 kern.info kernel: [ 173.068331] wlan-sta0: associate with e0:63:da:19:87:a7 (try 1/3)
Sat Jan 7 15:03:57 2023 kern.info kernel: [ 173.073502] wlan-sta0: RX AssocResp from e0:63:da:19:87:a7 (capab=0x1511 status=0 aid=1)
Sat Jan 7 15:03:57 2023 kern.info kernel: [ 173.077829] wlan-sta0: associated
Sat Jan 7 15:03:57 2023 daemon.notice netifd: Network device 'wlan-sta0' link is up
Sat Jan 7 15:03:57 2023 daemon.notice netifd: Interface 'wwan' is setting up now
Sat Jan 7 15:03:57 2023 daemon.notice wpa_supplicant[2479]: wlan-sta0: Associated with e0:63:da:19:87:a7
Sat Jan 7 15:03:57 2023 daemon.notice wpa_supplicant[2479]: wlan-sta0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Sat Jan 7 15:03:57 2023 daemon.info repeater: (/usr/sbin/repeater:472) IFNAME=wlan-sta0 <3>Associated with e0:63:da:19:87:a7
Sat Jan 7 15:03:57 2023 daemon.info repeater: (/usr/sbin/repeater:472) IFNAME=wlan-sta0 <3>CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Sat Jan 7 15:03:57 2023 daemon.notice netifd: wwan (13623): udhcpc: started, v1.33.2
Sat Jan 7 15:03:57 2023 daemon.notice netifd: wwan (13623): udhcpc: sending discover
Sat Jan 7 15:03:57 2023 daemon.notice wpa_supplicant[2479]: wlan-sta0: WPA: Key negotiation completed with e0:63:da:19:87:a7 [PTK=CCMP GTK=CCMP]
Sat Jan 7 15:03:57 2023 daemon.notice wpa_supplicant[2479]: wlan-sta0: CTRL-EVENT-CONNECTED - Connection to e0:63:da:19:87:a7 completed [id=0 id_str=]
Sat Jan 7 15:03:57 2023 daemon.info repeater: (/usr/sbin/repeater:472) IFNAME=wlan-sta0 <3>WPA: Key negotiation completed with e0:63:da:19:87:a7 [PTK=CCMP GTK=CCMP]
Sat Jan 7 15:03:57 2023 daemon.info repeater: (/usr/sbin/repeater:472) IFNAME=wlan-sta0 <3>CTRL-EVENT-CONNECTED - Connection to e0:63:da:19:87:a7 completed [id=0 id_str=]
Sat Jan 7 15:03:58 2023 kern.info kernel: [ 173.377527] ath11k c000000.wifi: bss color param 0x81000000 set on vdev 1
Sat Jan 7 15:03:59 2023 daemon.notice hostapd: wlan0-1: AP-STA-DISCONNECTED 40:cb:c0:b4:0d:c6 0 0
Sat Jan 7 15:03:59 2023 daemon.info hostapd: wlan0-1: STA 40:cb:c0:b4:0d:c6 IEEE 802.11: authenticated
Sat Jan 7 15:03:59 2023 daemon.info hostapd: wlan0-1: STA 40:cb:c0:b4:0d:c6 IEEE 802.11: associated (aid 1)
Sat Jan 7 15:03:59 2023 daemon.notice hostapd: wlan0-1: AP-STA-CONNECTED 40:cb:c0:b4:0d:c6 0 0
Sat Jan 7 15:03:59 2023 daemon.info hostapd: wlan0-1: STA 40:cb:c0:b4:0d:c6 RADIUS: starting accounting session 781B12F54A7C422A
Sat Jan 7 15:03:59 2023 daemon.info hostapd: wlan0-1: STA 40:cb:c0:b4:0d:c6 WPA: pairwise key handshake completed (RSN)
Sat Jan 7 15:04:01 2023 daemon.notice netifd: wwan (13623): udhcpc: sending discover
Sat Jan 7 15:04:01 2023 daemon.notice netifd: wwan (13623): udhcpc: sending select for 172.16.130.197
Sat Jan 7 15:04:01 2023 daemon.notice netifd: wwan (13623): udhcpc: lease of 172.16.130.197 obtained, lease time 28800
Sat Jan 7 15:04:01 2023 daemon.info avahi-daemon[3439]: Joining mDNS multicast group on interface wlan-sta0.IPv4 with address 172.16.130.197.
Sat Jan 7 15:04:01 2023 daemon.info avahi-daemon[3439]: New relevant interface wlan-sta0.IPv4 for mDNS.
Sat Jan 7 15:04:01 2023 daemon.info avahi-daemon[3439]: Registering new address record for 172.16.130.197 on wlan-sta0.IPv4.
Sat Jan 7 15:04:01 2023 daemon.notice netifd: Interface 'wwan' is now up
Sat Jan 7 15:04:01 2023 daemon.info dnsmasq[5810]: reading /tmp/resolv.conf.d/resolv.conf.auto
Sat Jan 7 15:04:01 2023 daemon.info dnsmasq[5810]: using only locally-known addresses for domain test
Sat Jan 7 15:04:01 2023 daemon.info dnsmasq[5810]: using only locally-known addresses for domain onion
Sat Jan 7 15:04:01 2023 daemon.info dnsmasq[5810]: using only locally-known addresses for domain localhost
Sat Jan 7 15:04:01 2023 daemon.info dnsmasq[5810]: using only locally-known addresses for domain invalid
Sat Jan 7 15:04:01 2023 daemon.info dnsmasq[5810]: using only locally-known addresses for domain bind
Sat Jan 7 15:04:01 2023 daemon.info dnsmasq[5810]: using only locally-known addresses for domain lan
Sat Jan 7 15:04:01 2023 daemon.info dnsmasq[5810]: using nameserver 208.91.112.53#53
Sat Jan 7 15:04:01 2023 daemon.info dnsmasq[5810]: using nameserver 208.91.112.52#53
Sat Jan 7 15:04:01 2023 user.notice mwan3[13950]: Execute ifup event on interface wwan (wlan-sta0)
Sat Jan 7 15:04:02 2023 user.notice mwan3[13950]: Starting tracker on interface wwan (wlan-sta0)
Sat Jan 7 15:04:02 2023 user.notice mwan3track[9577]: Stopping mwan3track for interface "wwan"
Sat Jan 7 15:04:03 2023 user.info mwan3rtmon[3212]: Detect rtchange event.
Sat Jan 7 15:04:04 2023 daemon.notice hostapd: wlan0-1: AP-STA-DISCONNECTED 4c:57:ca:7c:c4:80 0 0
Sat Jan 7 15:04:04 2023 daemon.info hostapd: wlan0-1: STA 4c:57:ca:7c:c4:80 IEEE 802.11: authenticated
Sat Jan 7 15:04:04 2023 daemon.info hostapd: wlan0-1: STA 4c:57:ca:7c:c4:80 IEEE 802.11: associated (aid 2)
Sat Jan 7 15:04:04 2023 daemon.notice hostapd: wlan0-1: AP-STA-CONNECTED 4c:57:ca:7c:c4:80 0 0
Sat Jan 7 15:04:04 2023 daemon.info hostapd: wlan0-1: STA 4c:57:ca:7c:c4:80 RADIUS: starting accounting session 746506F33653DEE8
Sat Jan 7 15:04:04 2023 daemon.info hostapd: wlan0-1: STA 4c:57:ca:7c:c4:80 WPA: pairwise key handshake completed (RSN)
Sat Jan 7 15:04:04 2023 user.notice firewall: Reloading firewall due to ifup of wwan (wlan-sta0)
Sat Jan 7 15:04:09 2023 user.info mwan3track[14320]: Lost 4 ping(s) on interface wwan (wlan-sta0)
Sat Jan 7 15:04:16 2023 daemon.info hostapd: wlan1: STA 4a:2d:f9:4c:0d:ae IEEE 802.11: authenticated
Sat Jan 7 15:04:16 2023 daemon.info hostapd: wlan1: STA 4a:2d:f9:4c:0d:ae IEEE 802.11: associated (aid 4)
Sat Jan 7 15:04:16 2023 daemon.notice hostapd: wlan1: AP-STA-CONNECTED 4a:2d:f9:4c:0d:ae 0 0
Sat Jan 7 15:04:16 2023 daemon.info hostapd: wlan1: STA 4a:2d:f9:4c:0d:ae RADIUS: starting accounting session EC13B52ED297DD51
Sat Jan 7 15:04:16 2023 daemon.info hostapd: wlan1: STA 4a:2d:f9:4c:0d:ae WPA: pairwise key handshake completed (RSN)
Sat Jan 7 15:04:16 2023 daemon.info dnsmasq-dhcp[5810]: DHCPREQUEST(br-lan) 192.168.8.193 4a:2d:f9:4c:0d:ae
Sat Jan 7 15:04:16 2023 daemon.info dnsmasq-dhcp[5810]: DHCPACK(br-lan) 192.168.8.193 4a:2d:f9:4c:0d:ae
Copyright © 2022 GL.iNet. All Rights Reserved
