I am using a dell laptop as a remote device which works fine using GLI app on Mac but when I use it on Surface Pro 11, I get Blank Screen.
Can you export the log in the help?
I have similar issue. Screen is blank when connecting to kvm from raspberry pi or freebsd. It works from linux. There is "H.264 - 1920x1080 / 0 kbps / 0 fps dynamic" in the status bar.
system_logs_20250616_142442.zip (35.1 KB)
My Issue was resolved after resetting Comet and connecting again.
