Virtual Display only when remotely connected
Hey all,
Is there a way to have the device create the virtual display only when you are connecting remotely? What I really want to accomplish is something like my moonlight setup where it disables my physical monitors and creates the virtual display when i login and then when i close it the virtual display disappears and my regular monitors turn back on.
Thanks
Sorry that Comet might have no idea to control a local monitor which connected to the controlled device.
But how about a fingerbot?
Use Comet to control it press the power switch in your monitor?
What you might need is a smart plug that can power on the GLKVM remotely when needed and turn off the power when it's not required.
