I have a ONT fiber optics modem, and my ISP provide an IPTV service and a device, when connecting the device directly to the ONT modem, it works perfectly, but when connecting it to the Convexa S it, shutter and not working correctly. I read about the problem, and found that I need to implement a VLAN bridge to make the IPTV device to connect directly to the ONT modem and obtaining it’s IP. how can I implement that on Convexa S.
I don’t think that this will work here is my concept
I have an ISP modem (ONT) which has network Ip range: 192.168.100.0/24
after that Modem I have the ( convexa-S) which is on router mode with Ip range: 192.168.8.0/24
I have an IPTV device from my ISP. I need it to be connected to the (Convexa-S) but to pull the IP from the (ONT modem). cause when the IPTV device be connected to another router, it shutter and disconnect.
how to make a VLAN bridge between this IPTV device and the (ONT modem) throught the Convexa-S) router?
Operators typically use MAC addresses to distinguish between devices, so, you can disguise your router as your IPTV with a MAC clone
Of course, I don’t guarantee it will work
