My requirements are 802.11r, 802.11s, and mesh routing with wired backhaul when available. This writeup has not tested wired backhaul. The most recent openwrt at the time of this writing does not have a great driver for the chipset in a GL-iNet B1300. The development release does. These are steps I followed:
Download firmware
Index of /snapshots/targets/ipq40xx/generic/
I downloaded:
https://downloads.openwrt.org/snapshots/targets/ipq40xx/generic/openwrt-ipq40xx-generic-glinet_gl-b1300-squashfs-sysupgrade.bin
from 2022/11/02.
Connect a laptop with the firmware, configured for 192.168.1.2.
Press the power on button and power on. Wait for five flashes or so.
You should get a firmware loader on http://192.168.1.1/
Load the firmware.
Wait for a reboot.
ssh [email protected]
passwd
cd /etc/config (Make sure you cd. I did not once, and something
happened in the edit and my changes were lost.) and edit nework
Find the line with 192.168.1.1. Change the IP to something you
can route on your network.
Add option gateway 'your-gateway.ip'
Add list dns '192.168.15.2'
You should end up with something like
config interface 'lan'
option proto 'static'
option ip6assign '60'
list dns_search 'localdomain'
option ipaddr '192.168.00.3'
option gateway '192.168.00.2'
option device 'br-lan'
list dns '192.168.00.2'
service network reload
. This will activate your port on an IP that you can download software and the like with. You will now need to plug in the B1300 into a switch connected ultiumately to the internet and that can route the IPs you just entered.
ssh root@<your-ip>
. At this point, I was not able to resolve dns names. Not sure why. I added my name server IP into /etc/resolv.conf manually.
Collected errors:
* check_data_file_clashes: Package libnl-tiny2022-05-23 wants to install file /usr/lib/libnl-tiny.so
But that file is already provided by package * libnl-tiny2022-11-01
* opkg_install_cmd: Cannot install package luci.
opkg remove --force-depends libnl-tiny2022-11-01
(yes, this could break something badly. This is a snapshot install.)
opkg update
opkg install luci-ssl
/etc/init.d/uhttpd restart
- Now you can access luci, the web interface at https://192.168.xx.yy/. At this point, you have flashed the latest copy of openwrt and gotte it working to the point where you can configure it. Yay! Now, my use case is a router providing all dns, dhcp and firewall services. So, I pay no attention to the wan port. I have smart switches ($30 in the US for a tp-link 8 port switch vs $20 for a dumb switch.), so I want to use VLANs to keep my traffic seperate and so I can use firewalls and different ESSIDs to allow different sorts of access. Onward! I should note that when I did this the first time, I had a packaging conflict of some sort. I had to force remove a package, but leave its dependancies. Not sure why that did not happen just now. Ah! Got the wrong image! The one I had on my laptop is different than my desktop. Must have flashed from the desktop first time. No matter.
uname -a
Linux ap-15-4 5.15.76 #0 SMP Wed Nov 2 11:41:56 2022 armv7l GNU/Linux
(new)
uname -a
Linux OpenWrt 5.10.146 #0 SMP Fri Oct 14 22:44:41 2022 armv7l GNU/Linux
(old)
So, let’s do this again, but we can do it from the desktop. We’ll have to retreat back to the laptop because we are going to get an error about using the old config format, I’ll bet. I was wondering why I did not see that this time, too. This time, I unchecked ‘Keep settings and retain current configuration’. If you want them, scp the files from /etc/config off the box first. Then flash. Also check ‘Force Update’. There are more options to think about if you are a long standing user of openwrt. I am not.
Go back to step 8.
And now from the status page: Firmware Version OpenWrt SNAPSHOT r21166-9721a42a27
Because I want 802.11s mesh, I am going to do:
opkg remove wpad-basic-wolfssl
opkg install wpad-mesh-openssl
Later on, I discovered that I had trouble with encryption on the mesh link, so I switched to wpad-mesh-wolfssl
. But, I am not certain I needed to do that. Maybe.
VLANS
So, I want to carry multiple VLANs on LAN port 1 (the middle port on the B1300). Because I want to carry multiple VLANs on the same port, I need to set the port on the phyiscal LAN switch the router is connected to be tagged and carry the VLANs I want. So, I’ll need to change my B1300, and then change the switch or have a port prepared so I can quickly move over and connect. If we do not move to a proper port quickly and reconnect to Luci, our changes could roll back.
So, I am going to prepare an extra port with the VLANs I’ll be needing so I’ll just have to move the network cable after I configure. (Good thing, the admin interface had timed out and I typed the password wrong).
In Luci, Network, Interfaces, Devices tab, Configure box.
- Bridge VLAN filtering. Enable VLAN filtering. I put VLANs 14 and 15 on port LAN 1, tagged. I left VLAN 15 undefined on LAN 2 and set VLAN 14 to u*. I should be able to plug in LAN 2 and get something on LAN 14, assuming I plug into an untagged VLAN 14 port on my switch. Not really a goal, but meh. Save, but you must NOT ‘save+apply’ yet!
- Oh, this assumes the default for br_lan on the general device options is to bridge ports LAN 1 and LAN 2. That was the default.
Network, Interfaces. Edit LAN
Change the device to be br-lan.<the-vlan>
. <the-vlan>
should be a tagged VLAN on your switch that has the static IP address you configured as part of the VLAN. Check bring up on boot
too. Give everything a look over. Click save.
So, now it comes time to do a save and apply. You will want to do the save and apply and move the network cable to a tagged port that matches the VLAN device you just set on the LAN interface. ready… go!. And it worked. I am now on tagged port. I am now going to copy the macaddr and ips, etc to a dhcp static entry on the router and convert to dhcp instead of manual. And it worked! I can see the lease on my router’s dhcp lease info area.
I’m going to want at least one extra interface, one where the VLAN will carry the wireless traffic, and potentially keep it seperated from the management and LAN ports. So, let’s do that.
Network, Interfaces, ‘Add new interface…’
The main thing is to connect it to the br_lan.<vlan>
interface you want to use to for the VLAN that will carry your wireless. I am going to put a management IP on here for now using DHCP, but I may remove it in the future, or make a maintenance ESSID with a different password and attach a management IP there, etc. Right now I want to keep things simple. Create the interface, bring up on boot, Save. Remember that most options like dhcp server, etc, do not matter to me. That will all just work. Save+apply.
Grab the macaddr and make a static DHCP entry. Restart the interface so it gets the static DHCP entry IP you just assigned.
Network, Global network options:
- Check packet steering, and then save+apply.
Network, Wireless
- Edit the radios, advanced settings, and set your country code. Do all radios. At least two, maybe three in general. Save+Apply
- Because I will be doing mesh, I also need to set my channels so all are the same. I am also going to set the security and ESSID while I’m here.
- Set the Network to be the VLAN based device you created above that will be used to carry your wireless traffic. Deselect ‘LAN’ unless you really want it. But, then why create VLANs?
- I am also going to enable 802.11r and set the mobility domain to be the same across all my devices. Save+Apply.. The radios are still not turned on.
Now I am going to add the 802.11s mesh device.
- Click add on the 5ghz radio, assuming you want mesh on 5ghz. For mode, select 802.11s. Select a mesh-id that will be the same. Something like my-mesh.
- Select the network. Now, I wonder what exactly my options here would be for a network? Clearly the VLAN device I created above, but could I use a different one? Not sure.
- Advanced Settings tab at the top, then Interface Configuration at the bottom, Wireless Security. WPA3-SAE and use the same password on all mesh devices. You do not type this when connecting to the wireless, only during setup, so it should be pretty random.
Note: encryption is not working at this time. I am not getting a connection. Using no encryption seems to work, but is not too ideal. But, 5ghz is not available very far off the property, if at all. So… I tried wpad-mesh-wolfssl instead. At first, it did not work, but an error in the log strongly suggested a reboot might help. So, I did and I now have a mesh connection with WPA3-SAE. The status for the connection still says encryption: none, though. UI error?
Save+Apply
End Notes
I think that’s it! I am now going to enable the radios and make a bunch of noise in here.
There seems to be a problem where it is hard to get the 5ghz radio to broadcast at 1 watt (30dbm). Eventually, it just sort of let me choose that value. Not sure why. No tricks being played.
Oh, one thing I keep forgetting. I was using an IP on VLAN 15 to do my edits when I was conneected directly to the device. However, now that they are deployed, I need to use a management IP on the VLAN associated with wireless (14 in my case).
Configs
network
config interface 'loopback'
option device 'lo'
option ipaddr '127.0.0.1'
option netmask '255.0.0.0'
config globals 'globals'
option ula_prefix 'fd02:10b1:604c::/48'
option packet_steering '1'
config device
option name 'br-lan'
option type 'bridge'
list ports 'lan1'
list ports 'lan2'
option bridge_empty '1'
option device 'br-lan.15'
option proto 'dhcp'
config interface 'wan'
option device 'wan'
option proto 'dhcp'
config interface 'wan6'
option device 'wan'
option proto 'dhcpv6'
config device
option name 'lan2'
config bridge-vlan
option vlan '15'
list ports 'lan1:t'
list ports 'lan2'
config bridge-vlan
option vlan '14'
list ports 'lan1:t'
list ports 'lan2:u*'
config interface 'LANOC288M'
option proto 'dhcp'
option device 'br-lan.14'
Wireless
config wifi-device 'radio0'
option type 'mac80211'
option path 'platform/soc/a000000.wifi'
option channel '1'
option band '2g'
option htmode 'HT20'
option country 'US'
option cell_density '0'
option txpower '30'
config wifi-iface 'default_radio0'
option device 'radio0'
option mode 'ap'
option ssid 'ESSID'
option encryption 'psk2'
option key 'PASSWORD'
option ieee80211r '1'
option mobility_domain '4HEXDIGITS'
option ft_over_ds '0'
option ft_psk_generate_local '1'
option network 'YOURNEWLANNAME'
config wifi-device 'radio1'
option path 'platform/soc/a800000.wifi'
option band '5g'
option htmode 'VHT80'
option country 'US'
option channel 'CHANNEL'
config wifi-iface 'default_radio1'
option device 'radio1'
option mode 'ap'
option ssid 'ESSID'
option nasid '1504'
config wifi-iface 'wifinet2'
option mode 'mesh'
option mesh_id 'ESSID-mesh'
option mesh_fwding '1'
option mesh_rssi_threshold '0'
option key 'SUPERSECRETPASSWORD'
option encryption 'sae'
