VoWiFi isn't working on my Flint 2
Hi, VoWiFi isn't working on my Flint 2. I have the 4.8.4 stable version installed via Uboot; I upgraded from the 4.8.4 nightly build.
My iPhone shows VoWiFi correctly when I connect it to other routers or access points, but not with the Flint.
Hi, I'm using the latest OP24 firmware (4.8.3). Everything works well and runs smoothly on Ukrainian carriers. Android smartphones
Check the essential ports UDP 500, 4500 if they’re blocked or not first.
Hi, UDP 500 and 4500 seems not blocked
Connection to 8.8.8.8 port 500 [udp/isakmp] succeeded!
Connection to 8.8.8.8 port 4500 [udp/ipsec-msft] succeeded!
Try changing DNS settings.
With what? I've tried the ISP's ones and Cloudflare's as well.
Depending on carrier, some expect their DNS without any intermediate strata like adguard. Is there any ad blocker enabled on the router?.
Every now and then, though, I notice that VoWiFi is active on my smartphone, so I don't think it's a DNS issue; I think it's something to do with the router settings. I just need to figure out what...
