[VPN] [2FA] Help setting up Pritunl VPN with 2FA on GL.iNet routers
I use a Pritunl VPN connection with two-factor authentication (2FA) for work. However, since there’s no 2FA prompt in the GL.iNet app or router UI, I’m not sure how to complete the login process.
Has anyone successfully connected to a Pritunl VPN that requires 2FA on GL.iNet? What’s the best way to configure it or work around the missing 2FA prompt?
I have Mango V2 and Slate AX
Pritunl VPN appears to be merely a VPN server management tools, and it is utilizing OpenVPN as its underlying protocol.
If the 2FA you mentioned refers to OpenVPN’s OTP option, please note that we do not currently provide official support for this feature.
However, you can refer to the following post for guidance on using an OTP update script to implement it:
