Was wondering if you guys are able to get the shadowsocks client and the vpn running at the same time?
You can only use one client but multiple servers at the same time.
How do you want the data goes through the ss and vpn tunnel?
I guess my question is, how to set up multi hop VPN in the router. Then I can jump between VPN servers
I would not recommend multi hop setup manually.
Maybe just try Tor.
Is there a reason to not recommend?
I configured a new config peer for wireguard in etc/config/wireguard.conf with the end points and public key of the servers. I kept the private key and IP address as the others were configured.
It looks like its working when i check dns leaks etc
Because it is difficult to set up.
