I’m trying to get my GL.iNet 300M Mini Smart Router’s OpenVPN client to connect to my OpenVPN instance at home, but it won’t let me, stating:
OpenVPN 2.5.0 mipsel-openwrt-linux-gnu [SSL (OpenSSL)] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
library versions: OpenSSL 1.1.1d 10 Sep 2019
NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
neither stdin nor stderr are a tty device and you have neither a controlling tty nor systemd - can't ask for 'Enter Private Key Password:'. If you used --daemon, you need to use --askpass to make passphrase-protected keys work, and you can not use --auth-nocache.
Exiting due to fatal error
VPN client failed to connect. This may be because of wrong configuration, unsupported parameters or terminated by the server. Please choose another VPN profile or abort the connection.
The profile file start with:
tls-client
nobind
dev tun
remote-cert-tls server
key-direction 1
redirect-gateway def1
dhcp-option DNS 192.168.1.1
remote x.y.z 1194 udp
client
nobind
dev tun
<key>
-----BEGIN ENCRYPTED PRIVATE KEY-----
The device’s firmware version is 3.201.
Can someone tell me how to fix this?
