Mon Jan 4 17:00:30 2021 daemon.notice netifd: Interface ‘lan’ is enabled
Mon Jan 4 17:00:30 2021 daemon.notice netifd: Interface ‘lan’ is setting up now
Mon Jan 4 17:00:30 2021 daemon.notice netifd: Interface ‘lan’ is now up
Mon Jan 4 17:00:30 2021 kern.info kernel: [19582.624329] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
Mon Jan 4 17:00:30 2021 daemon.notice netifd: Interface ‘lan1’ is enabled
Mon Jan 4 17:00:30 2021 kern.info kernel: [19582.641721] br-lan: port 2(lan1) entered blocking state
Mon Jan 4 17:00:30 2021 kern.info kernel: [19582.646980] br-lan: port 2(lan1) entered disabled state
Mon Jan 4 17:00:30 2021 kern.info kernel: [19582.661837] device lan1 entered promiscuous mode
Mon Jan 4 17:00:30 2021 kern.info kernel: [19582.691893] br-lan: port 3(usb0) entered blocking state
Mon Jan 4 17:00:30 2021 kern.info kernel: [19582.697333] br-lan: port 3(usb0) entered disabled state
Mon Jan 4 17:00:30 2021 kern.info kernel: [19582.707069] device usb0 entered promiscuous mode
Mon Jan 4 17:00:30 2021 daemon.notice netifd: Interface ‘loopback’ is enabled
Mon Jan 4 17:00:30 2021 daemon.notice netifd: Interface ‘loopback’ is setting up now
Mon Jan 4 17:00:30 2021 daemon.notice netifd: Interface ‘loopback’ is now up
Mon Jan 4 17:00:30 2021 kern.info kernel: [19582.722335] IPv6: ADDRCONF(NETDEV_UP): wan: link is not ready
Mon Jan 4 17:00:30 2021 daemon.notice netifd: Interface ‘wan’ is enabled
Mon Jan 4 17:00:30 2021 daemon.notice netifd: Interface ‘wan6’ is enabled
Mon Jan 4 17:00:30 2021 daemon.notice netifd: Network device ‘eth0’ link is up
Mon Jan 4 17:00:30 2021 daemon.notice netifd: Network device ‘lo’ link is up
Mon Jan 4 17:00:30 2021 daemon.notice netifd: Interface ‘loopback’ has link connectivity
Mon Jan 4 17:00:30 2021 daemon.notice netifd: radio0 (24468): sh: out of range
Mon Jan 4 17:00:31 2021 daemon.notice netifd: radio0 (24468): command failed: No such device (-19)
Mon Jan 4 17:00:31 2021 user.notice mac80211: Failed command: iw phy phy0 interface add wlan0 type __ap
Mon Jan 4 17:00:31 2021 daemon.err hostapd: Configuration file: /var/run/hostapd-phy0.conf
Mon Jan 4 17:00:31 2021 kern.info kernel: [19583.273045] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Mon Jan 4 17:00:31 2021 kern.info kernel: [19583.290788] br-lan: port 4(wlan0) entered blocking state
Mon Jan 4 17:00:31 2021 kern.info kernel: [19583.296139] br-lan: port 4(wlan0) entered disabled state
Mon Jan 4 17:00:31 2021 kern.info kernel: [19583.321799] device wlan0 entered promiscuous mode
Mon Jan 4 17:00:31 2021 daemon.notice hostapd: wlan0: interface state UNINITIALIZED->HT_SCAN
Mon Jan 4 17:00:31 2021 user.notice firewall: Reloading firewall due to ifup of lan (br-lan)
Mon Jan 4 17:00:31 2021 daemon.err odhcpd[1909]: Failed to send to ff02::1%lan@br-lan (Address not available)
Mon Jan 4 17:00:31 2021 kern.info kernel: [19583.804170] mv88e6085 d0032004.mdio-mii:01 wan: Link is Down
Mon Jan 4 17:00:32 2021 daemon.info dnsmasq[24154]: exiting on receipt of SIGTERM
Mon Jan 4 17:00:32 2021 daemon.info dnsmasq[24950]: started, version 2.80 cachesize 150
Mon Jan 4 17:00:32 2021 daemon.info dnsmasq[24950]: DNS service limited to local subnets
Mon Jan 4 17:00:32 2021 daemon.info dnsmasq[24950]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC no-ID loop-detect inotify dumpfile
Mon Jan 4 17:00:32 2021 daemon.info dnsmasq-dhcp[24950]: DHCP, IP range 192.168.8.100 – 192.168.8.249, lease time 12h
Mon Jan 4 17:00:32 2021 daemon.info dnsmasq[24950]: using local addresses only for domain test
Mon Jan 4 17:00:32 2021 daemon.info dnsmasq[24950]: using local addresses only for domain onion
Mon Jan 4 17:00:32 2021 daemon.info dnsmasq[24950]: using local addresses only for domain localhost
Mon Jan 4 17:00:32 2021 daemon.info dnsmasq[24950]: using local addresses only for domain invalid
Mon Jan 4 17:00:32 2021 daemon.info dnsmasq[24950]: using local addresses only for domain bind
Mon Jan 4 17:00:32 2021 daemon.info dnsmasq[24950]: using nameserver 127.0.0.1#53535
Mon Jan 4 17:00:32 2021 daemon.info dnsmasq[24950]: using local addresses only for domain lan
Mon Jan 4 17:00:32 2021 daemon.info dnsmasq[24950]: read /etc/hosts - 4 addresses
Mon Jan 4 17:00:32 2021 daemon.info dnsmasq[24950]: read /tmp/hosts/odhcpd - 0 addresses
Mon Jan 4 17:00:32 2021 daemon.info dnsmasq[24950]: read /tmp/hosts/dhcp.cfg01411c - 3 addresses
Mon Jan 4 17:00:32 2021 daemon.info dnsmasq-dhcp[24950]: read /etc/ethers - 0 addresses
Mon Jan 4 17:00:32 2021 daemon.notice hostapd: 20/40 MHz operation not permitted on channel pri=6 sec=10 based on overlapping BSSes
Mon Jan 4 17:00:32 2021 daemon.err hostapd: Using interface wlan0 with hwaddr d4:d2:d6:c2:21:4f and ssid “Sala”
Mon Jan 4 17:00:32 2021 kern.info kernel: [19584.875528] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Mon Jan 4 17:00:32 2021 kern.info kernel: [19584.882541] br-lan: port 4(wlan0) entered blocking state
Mon Jan 4 17:00:32 2021 kern.info kernel: [19584.887828] br-lan: port 4(wlan0) entered forwarding state
Mon Jan 4 17:00:32 2021 kern.info kernel: [19584.894236] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
Mon Jan 4 17:00:32 2021 daemon.notice netifd: bridge ‘br-lan’ link is up
Mon Jan 4 17:00:32 2021 daemon.notice netifd: Interface ‘lan’ has link connectivity
Mon Jan 4 17:00:32 2021 daemon.notice hostapd: wlan0: interface state HT_SCAN->ENABLED
Mon Jan 4 17:00:32 2021 daemon.notice hostapd: wlan0: AP-ENABLED
Mon Jan 4 17:00:32 2021 daemon.notice netifd: Network device ‘wlan0’ link is up
Mon Jan 4 17:00:33 2021 kern.info kernel: [19585.887190] mv88e6085 d0032004.mdio-mii:01 wan: Link is Up - 1Gbps/Full - flow control rx/tx
Mon Jan 4 17:00:33 2021 kern.info kernel: [19585.896415] IPv6: ADDRCONF(NETDEV_CHANGE): wan: link becomes ready
Mon Jan 4 17:00:33 2021 daemon.notice netifd: Network device ‘wan’ link is up
Mon Jan 4 17:00:33 2021 daemon.notice netifd: Interface ‘wan’ has link connectivity
Mon Jan 4 17:00:33 2021 daemon.notice netifd: Interface ‘wan’ is setting up now
Mon Jan 4 17:00:33 2021 daemon.notice netifd: Interface ‘wan6’ has link connectivity
Mon Jan 4 17:00:33 2021 daemon.notice netifd: Interface ‘wan6’ is setting up now
Mon Jan 4 17:00:33 2021 daemon.notice netifd: Interface ‘wan6’ is now up
Mon Jan 4 17:00:33 2021 daemon.err odhcpd[1909]: Failed to send to ff02::1%lan@br-lan (Address not available)
Mon Jan 4 17:00:33 2021 daemon.notice netifd: wan (25296): udhcpc: started, v1.30.1
Mon Jan 4 17:00:33 2021 daemon.notice netifd: wan (25296): udhcpc: sending discover
Mon Jan 4 17:00:34 2021 daemon.notice netifd: wan (25296): udhcpc: sending select for 10.0.0.240
Mon Jan 4 17:00:34 2021 daemon.notice netifd: wan (25296): udhcpc: lease of 10.0.0.240 obtained, lease time 172800
Mon Jan 4 17:00:34 2021 daemon.notice netifd: Interface ‘wan’ is now up
Mon Jan 4 17:00:34 2021 user.notice firewall: Reloading firewall due to ifup of wan6 (wan)
Mon Jan 4 17:00:34 2021 daemon.info dnsmasq[24950]: exiting on receipt of SIGTERM
Mon Jan 4 17:00:34 2021 daemon.info dnsmasq[25506]: started, version 2.80 cachesize 150
Mon Jan 4 17:00:34 2021 daemon.info dnsmasq[25506]: DNS service limited to local subnets
Mon Jan 4 17:00:34 2021 daemon.info dnsmasq[25506]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC no-ID loop-detect inotify dumpfile
Mon Jan 4 17:00:34 2021 daemon.info dnsmasq-dhcp[25506]: DHCP, IP range 192.168.8.100 – 192.168.8.249, lease time 12h
Mon Jan 4 17:00:34 2021 daemon.info dnsmasq[25506]: using local addresses only for domain test
Mon Jan 4 17:00:34 2021 daemon.info dnsmasq[25506]: using local addresses only for domain onion
Mon Jan 4 17:00:34 2021 daemon.info dnsmasq[25506]: using local addresses only for domain localhost
Mon Jan 4 17:00:34 2021 daemon.info dnsmasq[25506]: using local addresses only for domain invalid
Mon Jan 4 17:00:34 2021 daemon.info dnsmasq[25506]: using local addresses only for domain bind
Mon Jan 4 17:00:34 2021 daemon.info dnsmasq[25506]: using nameserver 127.0.0.1#53535
Mon Jan 4 17:00:34 2021 daemon.info dnsmasq[25506]: using local addresses only for domain lan
Mon Jan 4 17:00:34 2021 daemon.info dnsmasq[25506]: read /etc/hosts - 4 addresses
Mon Jan 4 17:00:34 2021 daemon.info dnsmasq[25506]: read /tmp/hosts/odhcpd - 0 addresses
Mon Jan 4 17:00:34 2021 daemon.info dnsmasq[25506]: read /tmp/hosts/dhcp.cfg01411c - 3 addresses
Mon Jan 4 17:00:34 2021 daemon.info dnsmasq-dhcp[25506]: read /etc/ethers - 0 addresses
Mon Jan 4 17:00:37 2021 user.notice firewall: Reloading firewall due to ifup of wan (wan)
Mon Jan 4 17:00:41 2021 daemon.info dnsmasq[25506]: exiting on receipt of SIGTERM
Mon Jan 4 17:00:41 2021 user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Mon Jan 4 17:00:41 2021 user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Mon Jan 4 17:00:41 2021 daemon.info dnsmasq[26515]: started, version 2.80 cachesize 150
Mon Jan 4 17:00:41 2021 daemon.info dnsmasq[26515]: DNS service limited to local subnets
Mon Jan 4 17:00:41 2021 daemon.info dnsmasq[26515]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC no-ID loop-detect inotify dumpfile
Mon Jan 4 17:00:41 2021 daemon.info dnsmasq-dhcp[26515]: DHCP, IP range 192.168.8.100 – 192.168.8.249, lease time 12h
Mon Jan 4 17:00:41 2021 daemon.info dnsmasq[26515]: using local addresses only for domain test
Mon Jan 4 17:00:41 2021 daemon.info dnsmasq[26515]: using local addresses only for domain onion
Mon Jan 4 17:00:41 2021 daemon.info dnsmasq[26515]: using local addresses only for domain localhost
Mon Jan 4 17:00:41 2021 daemon.info dnsmasq[26515]: using local addresses only for domain invalid
Mon Jan 4 17:00:41 2021 daemon.info dnsmasq[26515]: using local addresses only for domain bind
Mon Jan 4 17:00:41 2021 daemon.info dnsmasq[26515]: using nameserver 127.0.0.1#53535
Mon Jan 4 17:00:41 2021 daemon.info dnsmasq[26515]: using local addresses only for domain lan
Mon Jan 4 17:00:41 2021 daemon.info dnsmasq[26515]: read /etc/hosts - 4 addresses
Mon Jan 4 17:00:41 2021 daemon.info dnsmasq[26515]: read /tmp/hosts/odhcpd - 0 addresses
Mon Jan 4 17:00:41 2021 daemon.info dnsmasq[26515]: read /tmp/hosts/dhcp.cfg01411c - 3 addresses
Mon Jan 4 17:00:41 2021 daemon.info dnsmasq-dhcp[26515]: read /etc/ethers - 0 addresses
Mon Jan 4 17:08:06 2021 user.debug : command = curl -s --connect-timeout 5 checkip.dyndns.org | grep -m 1 -o ‘[0-9]{1,3}.[0-9]{1,3}.[0-9]{1,3}.[0-9]{1,3}’
Mon Jan 4 17:12:45 2021 user.info : The TCP Port 51820 Test OK
Mon Jan 4 17:12:45 2021 user.debug : ------ss-redir is not running!------
Mon Jan 4 17:27:15 2021 user.info : The TCP Port 51820 Test OK
Mon Jan 4 17:27:15 2021 user.debug : ------ss-redir is not running!------
Mon Jan 4 17:28:43 2021 user.debug : command = curl -s --connect-timeout 5 checkip.dyndns.org | grep -m 1 -o ‘[0-9]{1,3}.[0-9]{1,3}.[0-9]{1,3}.[0-9]{1,3}’
Mon Jan 4 17:52:27 2021 daemon.info dnsmasq[26515]: exiting on receipt of SIGTERM
Mon Jan 4 17:52:27 2021 user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Mon Jan 4 17:52:27 2021 user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Mon Jan 4 17:52:27 2021 daemon.info dnsmasq[32759]: started, version 2.80 cachesize 150
Mon Jan 4 17:52:27 2021 daemon.info dnsmasq[32759]: DNS service limited to local subnets
Mon Jan 4 17:52:27 2021 daemon.info dnsmasq[32759]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC no-ID loop-detect inotify dumpfile
Mon Jan 4 17:52:27 2021 daemon.info dnsmasq-dhcp[32759]: DHCP, IP range 192.168.8.100 – 192.168.8.249, lease time 12h
Mon Jan 4 17:52:27 2021 daemon.info dnsmasq[32759]: using local addresses only for domain test
Mon Jan 4 17:52:27 2021 daemon.info dnsmasq[32759]: using local addresses only for domain onion
Mon Jan 4 17:52:27 2021 daemon.info dnsmasq[32759]: using local addresses only for domain localhost
Mon Jan 4 17:52:27 2021 daemon.info dnsmasq[32759]: using local addresses only for domain invalid
Mon Jan 4 17:52:27 2021 daemon.info dnsmasq[32759]: using local addresses only for domain bind
Mon Jan 4 17:52:27 2021 daemon.info dnsmasq[32759]: using local addresses only for domain lan
Mon Jan 4 17:52:27 2021 daemon.info dnsmasq[32759]: reading /tmp/resolv.conf.auto
Mon Jan 4 17:52:27 2021 daemon.info dnsmasq[32759]: using nameserver 75.75.75.75#53
Mon Jan 4 17:52:27 2021 daemon.info dnsmasq[32759]: using nameserver 75.75.76.76#53
Mon Jan 4 17:52:27 2021 daemon.info dnsmasq[32759]: read /etc/hosts - 4 addresses
Mon Jan 4 17:52:27 2021 daemon.info dnsmasq[32759]: read /tmp/hosts/odhcpd - 0 addresses
Mon Jan 4 17:52:27 2021 daemon.info dnsmasq[32759]: read /tmp/hosts/dhcp.cfg01411c - 3 addresses
Mon Jan 4 17:52:27 2021 daemon.info dnsmasq-dhcp[32759]: read /etc/ethers - 0 addresses
Mon Jan 4 17:54:47 2021 user.debug : command = curl -s --connect-timeout 5 checkip.dyndns.org | grep -m 1 -o ‘[0-9]{1,3}.[0-9]{1,3}.[0-9]{1,3}.[0-9]{1,3}’
Mon Jan 4 19:15:27 2021 user.debug : command = curl -s --connect-timeout 5 checkip.dyndns.org | grep -m 1 -o ‘[0-9]{1,3}.[0-9]{1,3}.[0-9]{1,3}.[0-9]{1,3}’
Mon Jan 4 19:20:20 2021 user.info : The TCP Port 51820 Test OK
Mon Jan 4 19:20:20 2021 user.debug : ------ss-redir is not running!------
Mon Jan 4 19:52:28 2021 user.info : The TCP Port 51820 Test OK
Mon Jan 4 19:52:28 2021 user.debug : ------ss-redir is not running!------
Mon Jan 4 19:53:20 2021 user.debug : command = curl -s --connect-timeout 5 checkip.dyndns.org | grep -m 1 -o ‘[0-9]{1,3}.[0-9]{1,3}.[0-9]{1,3}.[0-9]{1,3}’
Mon Jan 4 20:20:03 2021 user.debug : command = curl -s --connect-timeout 5 checkip.dyndns.org | grep -m 1 -o ‘[0-9]{1,3}.[0-9]{1,3}.[0-9]{1,3}.[0-9]{1,3}’
Mon Jan 4 20:52:14 2021 user.info : The TCP Port 51820 Test OK
Mon Jan 4 20:52:14 2021 user.debug : ------ss-redir is not running!------
Mon Jan 4 20:52:43 2021 user.debug : command = curl -s --connect-timeout 5 checkip.dyndns.org | grep -m 1 -o ‘[0-9]{1,3}.[0-9]{1,3}.[0-9]{1,3}.[0-9]{1,3}’
Mon Jan 4 21:23:24 2021 user.info : The TCP Port 51820 Test OK
Mon Jan 4 21:23:24 2021 user.debug : ------ss-redir is not running!------
Mon Jan 4 21:23:48 2021 user.debug : command = curl -s --connect-timeout 5 checkip.dyndns.org | grep -m 1 -o ‘[0-9]{1,3}.[0-9]{1,3}.[0-9]{1,3}.[0-9]{1,3}’
Mon Jan 4 22:22:19 2021 user.debug : command = curl -s --connect-timeout 5 checkip.dyndns.org | grep -m 1 -o ‘[0-9]{1,3}.[0-9]{1,3}.[0-9]{1,3}.[0-9]{1,3}’
Mon Jan 4 22:22:48 2021 user.debug : command = curl -s --connect-timeout 5 checkip.dyndns.org | grep -m 1 -o ‘[0-9]{1,3}.[0-9]{1,3}.[0-9]{1,3}.[0-9]{1,3}’
Mon Jan 4 22:38:42 2021 daemon.info hostapd: wlan0: STA 66:7f:2e:bb:a1:ad IEEE 802.11: associated
Mon Jan 4 22:38:42 2021 daemon.notice hostapd: wlan0: AP-STA-CONNECTED 66:7f:2e:bb:a1:ad
Mon Jan 4 22:38:42 2021 daemon.info hostapd: wlan0: STA 66:7f:2e:bb:a1:ad RADIUS: starting accounting session 02320B6037FBC716
Mon Jan 4 22:38:42 2021 daemon.info hostapd: wlan0: STA 66:7f:2e:bb:a1:ad WPA: pairwise key handshake completed (RSN)
Mon Jan 4 22:38:46 2021 daemon.info dnsmasq-dhcp[32759]: DHCPDISCOVER(br-lan) 66:7f:2e:bb:a1:ad
Mon Jan 4 22:38:46 2021 daemon.info dnsmasq-dhcp[32759]: DHCPOFFER(br-lan) 192.168.8.170 66:7f:2e:bb:a1:ad
Mon Jan 4 22:38:46 2021 daemon.info dnsmasq-dhcp[32759]: DHCPREQUEST(br-lan) 192.168.8.170 66:7f:2e:bb:a1:ad
Mon Jan 4 22:38:46 2021 daemon.info dnsmasq-dhcp[32759]: DHCPACK(br-lan) 192.168.8.170 66:7f:2e:bb:a1:ad
Mon Jan 4 22:40:25 2021 daemon.info hostapd: wlan0: STA 66:7f:2e:bb:a1:ad IEEE 802.11: disassociated
Mon Jan 4 22:40:25 2021 daemon.notice hostapd: wlan0: AP-STA-DISCONNECTED 66:7f:2e:bb:a1:ad
