I’m using the 750S (Slate, 3.009) and try to establish a VPN-connection to my Raspberry Pi running an OpenVPN-server. The Raspberry works well with other VPN-clients.
First problem I had to solve was the askpass, which I had to add to the ovpn-file I got from my Raspberry Pi because at the Slate I had no chance to enter the password I had chosen. Solved.
Now I get the following error messages:
Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
TCP/UDP: Preserving recently used remote address: [AF_INET6]2003:d7:b7ff:22df:3631:c4ff:fe49:ef07:11941
Socket Buffers: R=[163840->163840] S=[163840->163840]
UDP link local: (not bound)
UDP link remote: [AF_INET6]2003:d7:b7ff:22df:3631:c4ff:fe49:ef07:11941
Did you try the configuration file on your PC directly? You can use the OpenVPN client to do that. Just need to confirm the configuration file is available at first.
I used the OPENVPN-client of my smartphone. It works well using the ovpn-file that Slate imported. I can use it over the mobile-net, over WLAN of my home router and over the WLAN of the Slate (when Slate is connected without own VPN).
Could you please check your OpenVPN’s key or certificate? To check if there has any line begin with the letter “u”, because it is a bug in old firmware, we had fixed it.
Is there maybe an other way to debug the device? I’m sceptical about giving out the configuration file and the password. The device is new and not changed. The Raspberry Pi with the OpenVPN-Server was installed with piVPN.
If everything is fine, it should work, but it says TLS handshake failed, not sure what’s wrong.
If you don’t like send the configuration file to someone, you can debug by yourself. Actually, you can upload the VPN configuration file to router via WinSCP, and start OpenVPN by manual, to see if it can work.
The addressed server was redirected by xxx.myfritz.net. I changed that to no-ip.com. Now it works. Strange, because a different device that uses the same ovpn-config works.
Don’t think so. Logged in at Slate, the smartphone connects to myfritz.net without problems and is forwarded to my Raspberry. On the Raspberry Pi works an OpenVPN-server.
