Hello GL.iNet community! I love the GL series routers having used several in the past and now currently using a Flint 2 at home and a Beryl AX for mobile usage. I've come across a particular issue which may be a firmware limitation but I wanted to bounce it off the wise minds of this forum.
Situation: I connect to an EAP network, usually directly from my computer and then use mullvad VPN client. this scenario works fine, but I am now using a rig that has several components which need connectivity so I brought out the Beryl AX. It connects perfectly fine to the EAP network using the latest op24 firmware (v4.6.3-op24), but if i try to enable mullvad via wireguard or openvpn, it fails with the following log:
Fri Aug 23 15:18:42 2024 daemon.notice netifd: Interface 'wgclient' is setting up now
Fri Aug 23 15:18:42 2024 daemon.notice netifd: wgclient (11035): RTNETLINK answers: Permission denied
Fri Aug 23 15:23:23 2024 daemon.notice ovpnclient[18456]: library versions: OpenSSL 3.0.14 4 Jun 2024, LZO 2.10
Fri Aug 23 15:23:23 2024 daemon.notice ovpnclient[18456]: Restart pause, 2 second(s)
Fri Aug 23 15:23:25 2024 daemon.warn ovpnclient[18456]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Fri Aug 23 15:23:25 2024 daemon.notice ovpnclient[18456]: TCP/UDP: Preserving recently used remote address: [AF_INET]127.0.0.1:1080
Fri Aug 23 15:23:25 2024 daemon.notice ovpnclient[18456]: Socket Buffers: R=[131072->425984] S=[16384->425984]
Fri Aug 23 15:23:25 2024 daemon.notice ovpnclient[18456]: Attempting to establish TCP connection with [AF_INET]127.0.0.1:1080
Fri Aug 23 15:23:25 2024 daemon.err ovpnclient[18456]: TCP: connect to [AF_INET]127.0.0.1:1080 failed: Connection refused
Fri Aug 23 15:23:25 2024 daemon.notice ovpnclient[18456]: SIGHUP[soft,connection-failed] received, process restarting
Fri Aug 23 15:23:25 2024 daemon.notice ovpnclient[18456]: OpenVPN 2.6.10 aarch64-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
Fri Aug 23 15:23:25 2024 daemon.notice ovpnclient[18456]: library versions: OpenSSL 3.0.14 4 Jun 2024, LZO 2.10
Fri Aug 23 15:23:25 2024 daemon.notice ovpnclient[18456]: Restart pause, 2 second(s)
Fri Aug 23 15:23:27 2024 daemon.warn ovpnclient[18456]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Fri Aug 23 15:23:27 2024 daemon.notice ovpnclient[18456]: TCP/UDP: Preserving recently used remote address: [AF_INET]127.0.0.1:1080
Fri Aug 23 15:23:27 2024 daemon.notice ovpnclient[18456]: Socket Buffers: R=[131072->425984] S=[16384->425984]
Fri Aug 23 15:23:27 2024 daemon.notice ovpnclient[18456]: Attempting to establish TCP connection with [AF_INET]127.0.0.1:1080
Fri Aug 23 15:23:27 2024 daemon.err ovpnclient[18456]: TCP: connect to [AF_INET]127.0.0.1:1080 failed: Connection refused
Fri Aug 23 15:23:27 2024 daemon.notice ovpnclient[18456]: SIGHUP[soft,connection-failed] received, process restarting
Fri Aug 23 15:23:27 2024 daemon.notice ovpnclient[18456]: OpenVPN 2.6.10 aarch64-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
Fri Aug 23 15:23:27 2024 daemon.notice ovpnclient[18456]: library versions: OpenSSL 3.0.14 4 Jun 2024, LZO 2.10
Fri Aug 23 15:23:27 2024 daemon.notice ovpnclient[18456]: Restart pause, 2 second(s)
I should note that I believe the hotel connection that I am using does use anti-vpn countermeasures but I am still able to connect via the windows mullvad client when I enable "obfuscation". Is there any way to enable this on the router?
Any advice on how to get this up and running would be greatly appreciated!
