VPN Connection Issue "No group found" - Flint 2 GL-MT6000 (Firmware 4.7.0)
I am using the Flint 2 GL-MT6000 router updated to the latest firmware version 4.7.0 and the GL.iNet app for Android version 2.6.1. I have had an active Windscribe Pro subscription for almost a year, and until the recent update, everything worked correctly with the VPN configured directly on the router.
After the update, I’m experiencing the following issue:
Whenever I attempt to connect to the VPN, I get a red message saying "No group found", and the connection fails.
I have already tried the following:
Verified the VPN configuration.
Restarted the router.
Logged in again to the Windscribe service.
I kindly ask for support to understand how to resolve this issue and restore the proper functioning of the VPN.
Thank you in advance for your help!
Device: Flint 2 GL-MT6000
Firmware: 4.7.0
GL.iNet App: 2.6.1 (Android)
VPN Service: Windscribe Pro
The issue we are aware now, thank you, please downgrade manually to the last one version, to continue to use first.
Sorry. R&D will check this issue ASAP.
Hi @bruce
Can you please confirm the latest firmware release that still works? ie which release we should be downgrading to?
Cheers
The latest version has not updated this fix.
Please downgrade to v4.6.4 if you required to use the Windscribe.
4.7.4 beta 1 works well with Windscribe.
