Yeah, a reboot of both devices wouldn’t hurt.
Another PRO-TIP: Use Incognito/Private Mode when logging into a router. The browser’s caching can cause weird problems otherwise.
Hi again.
I think ive found whats the issue…
I had another laptop with windows on it. Tried to conenct to the router with ethernet… It got 192.168.8.1…
and the name shows my WIFI name for it!
Looks like i have 2 IPs now. on windows ( ethernet ) and on ubuntu ( wifi ) it detects 8.1 but on Ubuntu ( ethernet ) it detects 1.1
Sorry for trouble
Reboot/power cycle everything that is using Wi-Fi or a cable. That will help ‘clear the air.’
Post the output of cat /etc/openwrt_release , pls.
DISTRIB_ID='OpenWrt'
DISTRIB_RELEASE='SNAPSHOT'
DISTRIB_REVISION='r24909-65f599223d'
DISTRIB_TARGET='mediatek/filogic'
DISTRIB_ARCH='aarch64_cortex-a53'
DISTRIB_DESCRIPTION='OpenWrt SNAPSHOT r24909-65f599223d'
DISTRIB_TAINTS=''
root@GL-MT6000:~#
Congratulations; you’re running stock OpenWrt 23.05 for the Flint v2 (GL-MT6000), developer SNAPSHOT (r24909-65f599223d).
Post the output of netstat -natp , pls.
Active Internet connections (servers and established)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 192.168.8.1:53 0.0.0.0:* LISTEN 2198/dnsmasq
tcp 0 0 127.0.0.1:53 0.0.0.0:* LISTEN 2198/dnsmasq
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 1368/dropbear
tcp 0 196 192.168.8.1:22 192.168.8.183:48284 ESTABLISHED 2698/dropbear
tcp 0 0 ::1:53 :::* LISTEN 2198/dnsmasq
tcp 0 0 fde6:9715:944e::1:53 :::* LISTEN 2198/dnsmasq
tcp 0 0 fe80::9683:c4ff:fea7:29ec:53 :::* LISTEN 2198/dnsmasq
tcp 0 0 fe80::84db:89ff:fe85:f5e6:53 :::* LISTEN 2198/dnsmasq
tcp 0 0 :::22 :::* LISTEN 1368/dropbear
root@GL-MT6000:~#
It’s looking good. Post the output of ifconfig , pls.
br-lan Link encap:Ethernet HWaddr 94:83:C4:A7:29:EC
inet addr:192.168.8.1 Bcast:192.168.8.255 Mask:255.255.255.0
inet6 addr: fe80::9683:c4ff:fea7:29ec/64 Scope:Link
inet6 addr: fde6:9715:944e::1/60 Scope:Global
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:13420 errors:0 dropped:0 overruns:0 frame:0
TX packets:603 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:2862957 (2.7 MiB) TX bytes:96506 (94.2 KiB)
eth0 Link encap:Ethernet HWaddr 86:DB:89:85:F5:E6
inet6 addr: fe80::84db:89ff:fe85:f5e6/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1504 Metric:1
RX packets:1849 errors:0 dropped:0 overruns:0 frame:0
TX packets:69 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:127739 (124.7 KiB) TX bytes:9384 (9.1 KiB)
Interrupt:130
eth1 Link encap:Ethernet HWaddr 94:83:C4:A7:29:EA
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:130
lan1 Link encap:Ethernet HWaddr 94:83:C4:A7:29:EB
lan2 Link encap:Ethernet HWaddr 94:83:C4:A7:29:EC
lan3 Link encap:Ethernet HWaddr 94:83:C4:A7:29:EC
lan4 Link encap:Ethernet HWaddr 94:83:C4:A7:29:EC
lan5 Link encap:Ethernet HWaddr 94:83:C4:A7:29:EC
TX packets:53 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:94457 (92.2 KiB) TX bytes:7042 (6.8 KiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:4220 errors:0 dropped:0 overruns:0 frame:0
TX packets:4220 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:333250 (325.4 KiB) TX bytes:333250 (325.4 KiB)
wlan0 Link encap:Ethernet HWaddr 94:83:C4:A7:29:ED
RX packets:8410 errors:0 dropped:0 overruns:0 frame:0
TX packets:3221 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:630126 (615.3 KiB) TX bytes:277405 (270.9 KiB)
wlan1 Link encap:Ethernet HWaddr 94:83:C4:A7:29:EE
RX packets:3175 errors:0 dropped:0 overruns:0 frame:0
TX packets:3178 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:2302070 (2.1 MiB) TX bytes:316947 (309.5 KiB)
root@GL-MT6000:~#
Yup; that almost confirms it in full for me. Post the output of uname --all , pls.
root@GL-MT6000:~# uname --all
Linux GL-MT6000 5.15.147 #0 SMP Thu Jan 25 22:45:41 2024 aarch64 GNU/Linux
root@GL-MT6000:~#
Okay, one final check I think: let’s see if LuCI is on the system. Post the out of find / -iname "luci" . There may not be any. That’s OK.
root@GL-MT6000:~# find / -iname "luci"
find: unrecognized: .
BusyBox v1.36.1 (2024-01-25 22:45:41 UTC) multi-call binary.
Usage: find [-HL] [PATH]... [OPTIONS] [ACTIONS]
Search for files and perform actions on them.
First failed action stops processing of current file.
Defaults: PATH is current directory, action is '-print'
-L,-follow Follow symlinks
-H ...on command line only
-xdev Don't descend directories on other filesystems
-maxdepth N Descend at most N levels. -maxdepth 0 applies
actions to command line arguments only
-mindepth N Don't act on first N levels
-depth Act on directory *after* traversing it
Actions:
( ACTIONS ) Group actions for -o / -a
! ACT Invert ACT's success/failure
ACT1 [-a] ACT2 If ACT1 fails, stop, else do ACT2
ACT1 -o ACT2 If ACT1 succeeds, stop, else do ACT2
Note: -a has higher priority than -o
-name PATTERN Match file name (w/o directory name) to PATTERN
-iname PATTERN Case insensitive -name
-path PATTERN Match path to PATTERN
-ipath PATTERN Case insensitive -path
-regex PATTERN Match path to regex PATTERN
-type X File type is X (one of: f,d,l,b,c,s,p)
-perm MASK At least one mask bit (+MASK), all bits (-MASK),
or exactly MASK bits are set in file's mode
-mtime DAYS mtime is greater than (+N), less than (-N),
or exactly N days in the past
-mmin MINS mtime is greater than (+N), less than (-N),
or exactly N minutes in the past
-newer FILE mtime is more recent than FILE's
-user NAME/ID File is owned by given user
-group NAME/ID File is owned by given group
-size N[bck] File size is N (c:bytes,k:kbytes,b:512 bytes(def.))
+/-N: file size is bigger/smaller than N
-prune If current file is directory, don't descend into it
If none of the following actions is specified, -print is assumed
-print Print file name
-print0 Print file name, NUL terminated
-exec CMD ARG ; Run CMD with all instances of {} replaced by
file name. Fails if CMD exits with nonzero
root@GL-MT6000:~#
That’s odd but not in a bad way; let’s try ls -l /etc/config/ . I’d like to see what stock configurations are listed before we see about getting LuCI downloaded.
root@GL-MT6000:~# ls -l /etc/config/
-rwxr-xr-x 1 root root 343 Jan 25 06:38 TRL
-rw-r--r-- 1 root root 74 Jan 18 02:00 adguardhome
-rw-r--r-- 1 root root 1072 Oct 10 01:15 apnprofile
-rw-r--r-- 1 root root 136 Oct 10 01:15 board_special
-rw-r--r-- 1 root root 97 Jan 5 13:53 bridger
-rw-r--r-- 1 root root 68 Oct 10 01:15 custom_apn
-rw------- 1 root root 933 Oct 10 01:15 ddns
-rw------- 1 root root 1467 Jan 22 07:11 dhcp
-rw------- 1 root root 134 Oct 10 01:15 dropbear
-rw-r--r-- 1 root root 140 Oct 10 01:15 edgerouter
-rw-r--r-- 1 root root 5413 Jan 25 06:49 firewall
-rw-r--r-- 1 root root 374 Oct 10 01:15 fstab
-rw-r--r-- 1 root root 46 Oct 10 01:15 fullconenat
-rw------- 1 root root 239 Jan 25 06:37 gl-black_white_list
-rw-r--r-- 1 root root 542 Jan 15 17:46 gl-client
-rw------- 1 root root 65 Oct 10 01:15 gl-cloud
-rw------- 1 root root 55 Jan 22 07:08 gl-dns
-rw------- 1 root root 342 Oct 10 01:15 gl-tertf
-rw------- 1 root root 0 Oct 10 01:15 gl_block
-rwxr-xr-x 1 root root 102 Oct 10 01:15 gl_ddns
-rw-r--r-- 1 root root 68 Oct 10 01:15 gl_led
-rwxr-xr-x 1 root root 50 Oct 10 01:15 gl_logread
-rw------- 1 root root 47 Oct 10 01:15 gl_macclone
drwxr-xr-x 2 root root 3488 Jan 1 1970 gl_nas
-rwxr-xr-x 1 root root 63 Oct 10 01:15 gl_s2s
-rw-r--r-- 1 root root 2082 Oct 10 01:15 gl_timer
-rw-r--r-- 1 root root 373 Jan 18 01:51 glconfig
-rwxr-xr-x 1 root root 300 Oct 10 01:15 glipv6
-rw-r--r-- 1 root root 86 Oct 10 01:15 glmodem
-rwxr-xr-x 1 root root 2596 Jan 25 07:00 kmwan
-rw-r--r-- 1 root root 1018 Oct 10 01:15 luci
-rw------- 1 root root 610 Jan 15 05:08 minidlna
-rw-r--r-- 1 root root 253 Jan 15 05:08 nas
-rw------- 1 root root 2881 Jan 25 06:49 network
-rw-r--r-- 1 root root 46 Oct 10 01:15 openssl
-rw------- 1 root root 16714 Oct 10 01:15 openvpn
-rw------- 1 root root 353 Jan 15 18:44 oui-httpd
-rw-r--r-- 1 root root 3023 Jan 15 03:12 ovpnclient
-rw-r--r-- 1 root root 593 Oct 10 01:15 ovpnserver
-rwxr-xr-x 1 root root 413 Jan 22 06:48 parental_control
-rwxr-xr-x 1 root root 85 Jan 25 06:49 plugins
-rw-r--r-- 1 root root 547 Oct 10 01:15 qos
-rw-r--r-- 1 root root 264 Oct 10 01:15 radius
-rw------- 1 root root 107 Oct 10 01:15 repeater
-rw------- 1 root root 167 Oct 10 01:15 rpcd
-rw------- 1 root root 24 Oct 10 01:15 rtty
-rw------- 1 root root 134 Jan 15 05:08 samba4
-rw-r--r-- 1 root root 63 Jan 25 06:37 sip_alg
-rw------- 1 root root 757 Jan 22 06:56 stubby
-rw-r--r-- 1 root root 11 Oct 10 01:15 switch-button
-rw------- 1 root root 476 Jan 15 17:43 system
-rw-r--r-- 1 root root 147 Oct 10 01:15 tailscale
-rw-r--r-- 1 root root 86 Jan 22 07:44 tor
-rw-r--r-- 1 root root 94 Oct 10 01:15 ubootenv
-rw-r--r-- 1 root root 788 Oct 10 01:15 ucitrack
-rw------- 1 root root 117 Oct 10 01:15 upgrade
-rw-r--r-- 1 root root 243 Jan 25 06:47 vpnpolicy
-rw------- 1 root root 189 Oct 10 01:15 wan-access
-rw-r--r-- 1 root root 12246 Jan 15 18:26 wireguard
-rwxr-xr-x 1 root root 376 Jan 15 18:29 wireguard_server
-rw-r--r-- 1 root root 1683 Jan 15 17:22 wireless
-rw-r--r-- 1 root root 79 Oct 10 01:15 zerotier
root@GL-MT6000:~#
Oh my; so all those gl_ files tell me the Flint v2’s flash wasn’t completely overwritten when the OWRT snapshot was flashed. That may not be a problem… but let’s check: pls post the output of ps -w; uptime ; I’d like to see what processes/programs are running ATM.
root@GL-MT6000:~# ps -w; uptime
PID USER VSZ STAT COMMAND
1 root 2268 S /sbin/procd
2 root 0 SW [kthreadd]
3 root 0 IW< [rcu_gp]
4 root 0 IW< [rcu_par_gp]
5 root 0 IW< [slub_flushwq]
6 root 0 IW< [netns]
8 root 0 IW< [kworker/0:0H-mm]
10 root 0 IW< [mm_percpu_wq]
11 root 0 SW [rcu_tasks_trace]
12 root 0 SW [ksoftirqd/0]
13 root 0 IW [rcu_sched]
14 root 0 SW [migration/0]
15 root 0 SW [cpuhp/0]
16 root 0 SW [cpuhp/1]
17 root 0 SW [migration/1]
18 root 0 SW [ksoftirqd/1]
20 root 0 IW< [kworker/1:0H-kb]
21 root 0 SW [cpuhp/2]
22 root 0 SW [migration/2]
23 root 0 SW [ksoftirqd/2]
25 root 0 IW< [kworker/2:0H-ev]
26 root 0 SW [cpuhp/3]
27 root 0 SW [migration/3]
28 root 0 SW [ksoftirqd/3]
30 root 0 IW< [kworker/3:0H-ev]
31 root 0 IW< [inet_frag_wq]
33 root 0 SW [oom_reaper]
34 root 0 IW< [writeback]
35 root 0 SW [kcompactd0]
45 root 0 IW< [pencrypt_serial]
46 root 0 IW< [pdecrypt_serial]
48 root 0 IW< [cryptd]
52 root 0 IW [kworker/2:1-rcu]
74 root 0 IW< [kblockd]
75 root 0 IW< [blkcg_punt_bio]
76 root 0 IW< [ata_sff]
77 root 0 IW [kworker/1:2-eve]
78 root 0 SW [watchdogd]
115 root 0 IW [kworker/u8:2-ev]
116 root 0 SW [kswapd0]
117 root 0 IW< [kworker/2:1H-kb]
120 root 0 IW< [kthrotld]
224 root 0 SW [hwrng]
225 root 0 IW [kworker/3:2-rcu]
255 root 0 IW< [iscsi_eh]
257 root 0 IW< [iscsi_conn_clea]
385 root 0 SW [napi/mtk_eth-5]
386 root 0 SW [napi/mtk_eth-6]
414 root 0 IW< [mld]
416 root 0 IW< [ipv6_addrconf]
417 root 0 IW< [kworker/3:1H-kb]
430 root 0 IW< [dsa_ordered]
431 root 0 IW [kworker/3:5-eve]
432 root 0 IW< [kstrp]
440 root 0 SW [irq/82-mt7530]
458 root 0 IW< [mmc_complete]
463 root 0 IW< [kworker/0:1H-kb]
487 root 0 SW [irq/63-mdio-bus]
502 root 0 SW [irq/25-keys]
543 root 0 IW< [kworker/1:1H]
624 root 0 SW [f2fs_ckpt-7:0]
625 root 0 SW [f2fs_flush-7:0]
626 root 0 SW [f2fs_gc-7:0]
690 ubus 1436 S /sbin/ubusd
691 root 908 S /sbin/askfirst /usr/libexec/login.sh
726 root 1064 S /sbin/urngd
793 root 0 SW [irq/117-1032000]
794 root 0 IW< [wq_ring0]
795 root 0 SW [irq/118-1032000]
796 root 0 IW< [wq_ring1]
797 root 0 SW [irq/119-1032000]
798 root 0 IW< [wq_ring2]
799 root 0 SW [irq/120-1032000]
800 root 0 IW< [wq_ring3]
855 root 0 IW [kworker/1:3-pm]
868 root 0 IW< [cfg80211]
877 root 0 SW [napi/phy0-7]
878 root 0 SW [napi/phy0-8]
879 root 0 SW [napi/phy0-9]
880 root 0 SW [napi/phy0-10]
881 root 0 SW [napi/phy0-11]
882 root 0 SW [napi/phy0-12]
887 root 0 SW [mt76-tx phy0]
948 root 0 IW [kworker/0:3-eve]
1166 logd 1976 S /sbin/logd -S 64
1368 root 1108 S /usr/sbin/dropbear -F -P /var/run/dropbear.1.pid -p 22 -K 300 -T 3 -W 262144
1472 root 2828 S {hostapd} /sbin/ujail -t 5 -n hostapd -U network -G network -C /etc/capabilities/wpad.json -c -- /usr/sbi
1473 root 2828 S {wpa_supplicant} /sbin/ujail -t 5 -n wpa_supplicant -U network -G network -C /etc/capabilities/wpad.json
1475 network 4736 S /usr/sbin/wpa_supplicant -n -s -g /var/run/wpa_supplicant/global
1476 network 4972 S /usr/sbin/hostapd -s -g /var/run/hostapd/global
1537 root 2740 S /sbin/netifd
1653 root 1616 S /usr/sbin/odhcpd
1891 root 0 SW [irq/62-mdio-bus]
1924 root 2828 S {ntpd} /sbin/ujail -t 5 -n ntpd -U ntp -G ntp -C /etc/capabilities/ntpd.json -c -u -r /bin/ubus -r /usr/b
1928 ntp 1316 S /usr/sbin/ntpd -n -N -S /usr/sbin/ntpd-hotplug -p 0.openwrt.pool.ntp.org -p 1.openwrt.pool.ntp.org -p 2.o
2194 root 2828 S {dnsmasq} /sbin/ujail -t 5 -n dnsmasq -u -l -r /bin/ubus -r /etc/TZ -r /etc/dnsmasq.conf -r /etc/ethers -
2198 dnsmasq 1556 S /usr/sbin/dnsmasq -C /var/etc/dnsmasq.conf.cfg01411c -k -x /var/run/dnsmasq/dnsmasq.cfg01411c.pid
2667 root 0 IW [kworker/2:0-mm_]
2698 root 1128 R /usr/sbin/dropbear -F -P /var/run/dropbear.1.pid -p 22 -K 300 -T 3 -W 262144 -2 9
2705 root 1328 S -ash
2739 root 0 IW [kworker/0:1]
2741 root 0 IW [kworker/u8:0-ev]
2759 root 0 IW [kworker/u8:1-ev]
2774 root 0 IW [kworker/0:0]
2779 root 1324 R ps -w
03:18:37 up 40 min, load average: 0.00, 0.00, 0.00
root@GL-MT6000:~#
Nice & clean. So those files in /etc/config/ now have no longer used GL-related configuration files in that directory. I don’t think it’s anything to worry about. It’s just cruft but shouldn’t impact anything. Because of this cruft I’m going to update the proper command to download LuCI. Standby…
Thank you so much for your time and effort i deeply appreciate this <3
