Ok thank you very much for your time. Please take your time. and i just installed file zilla
Save this on your Ubuntu computer as owrt_-_get_usb.sh in a UTF-8/LF encoded text file (which is the default encoding in Linux). I suggest making a temp dir in your home directory for it. Then chmod +x owrt_-_get_usb.sh to make it executable. It will create an owrt_usb_ipks dir to pull the ipks down into.
To do that run ./owrt_-_get_usb.sh download .
This is untested on my end so pls post any output.
#!/bin/sh
# 2024-01-27-2326
# DESCRIPTION
# Download required OWRT packages for using a USB flash disk on a Linux compute
# r. Then install them once SCP'd over to the OWRT device.
# NOTE
# This does not include packages required for using mechanical (HDD) USB disks.
# USAGE
# chmod +x owrt_-_get_usb.sh; ./owrt_-_get_usb.sh {download, install}
# References:
# https://openwrt.org/docs/guide-user/storage/usb-drives
if [ $# -ne 1 ]; then
echo "This script requires exactly one argument passed to it."
echo "to download the OWRT USB packages type 'download'"
echo "to install type 'install' fr the same dir as the ipks."
exit 1
fi
IPKGS="kmod-usb-storage
kmod-usb-storage-uas
usbutils
block-mount
libblkid
gdisk
parted
e2fsprogs
kmod-fs-ext4
kmod-fs-exfat
f2fs-tools
kmod-fs-f2fs"
if [ "$1" = "download" ]; then
for i in $IPKGS; do
if [ ! -d owrt_usb_ipks ]; then
mkdir owrt_usb_ipks
fi
cd owrt_usb_ipks || return
wget https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/"$i"
done
fi
if [ "$1" = "install" ]; then
for i in $IPKGS; do
opkg install --force-reinstall --force-overwrite "$i"
done
fi
exit 0
Once we know this works for downloading we’ll move onto getting the ipks installed on the Flint v2.
angelina@angelina-Predator-PH315-51:~$ chmod +x owrt_-_get_usb.sh
angelina@angelina-Predator-PH315-51:~$ ./owrt_-_get_usb.sh download
--2024-01-27 04:40:57-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/kmod-usb-storage
Resolving downloads.openwrt.org (downloads.openwrt.org)... 151.101.210.132
Connecting to downloads.openwrt.org (downloads.openwrt.org)|151.101.210.132|:443... connected.
HTTP request sent, awaiting response... 404 Not Found
2024-01-27 04:40:59 ERROR 404: Not Found.
--2024-01-27 04:40:59-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/kmod-usb-storage-uas
2024-01-27 04:41:02 ERROR 404: Not Found.
--2024-01-27 04:41:02-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/usbutils
2024-01-27 04:41:04 ERROR 404: Not Found.
--2024-01-27 04:41:04-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/block-mount
2024-01-27 04:41:06 ERROR 404: Not Found.
--2024-01-27 04:41:06-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/libblkid
2024-01-27 04:41:08 ERROR 404: Not Found.
--2024-01-27 04:41:08-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/gdisk
2024-01-27 04:41:10 ERROR 404: Not Found.
--2024-01-27 04:41:10-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/parted
2024-01-27 04:41:12 ERROR 404: Not Found.
--2024-01-27 04:41:12-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/e2fsprogs
2024-01-27 04:41:14 ERROR 404: Not Found.
--2024-01-27 04:41:14-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/kmod-fs-ext4
2024-01-27 04:41:16 ERROR 404: Not Found.
--2024-01-27 04:41:16-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/kmod-fs-exfat
2024-01-27 04:41:18 ERROR 404: Not Found.
--2024-01-27 04:41:18-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/f2fs-tools
2024-01-27 04:41:20 ERROR 404: Not Found.
--2024-01-27 04:41:20-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/kmod-fs-f2fs
2024-01-27 04:41:22 ERROR 404: Not Found.
Goddamnit; that’s my fault. I have to work out a way to pull down the complete ipk file name instead of just assuming the same method of opkg install $ipk works when trying to download 'em offline.
Stanby…
Pls give this a shot. Same command to execute.
#!/bin/sh
# 2024-01-27-0016
# DESCRIPTION
# NOTE
# USAGE
# References:
exit 1
fi
kmod-usb-storage-extras
usbutils
block-mount
libblkid
gdisk
parted
e2fsprogs
kmod-fs-ext4
kmod-fs-exfat
f2fs-tools
kmod-fs-f2fs"
for i in $IPKGS; do
mkdir owrt_usb_ipks
fi
wget -O owrt_packages_index.html https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/
# grep "$i" owrt_packages_index.html | grep "href" | cut -d "\"" -f 4 | cut -d "\"" -f 1
for ipk in $(grep "$IPKGS" owrt_packages_index.html | grep "href" | cut -d "\"" -f 4 | cut -d "\"" -f 1); do
wget https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/"$ipk"
done
done
fi
for i in $IPKGS; do
done
fi
exit 0
Thank you seems liek downloaded… I dont know how do u even do this. It seems so complicated.
Just couldnt fit all… Says max is 32k character here.
--2024-01-27 05:21:00-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/
HTTP request sent, awaiting response... 200 OK
Length: 231939 (227K) [text/html]
Saving to: ‘owrt_packages_index.html’
owrt_packages_index 100%[===================>] 226.50K 172KB/s in 1.3s
2024-01-27 05:21:08 (172 KB/s) - ‘owrt_packages_index.html’ saved [231939/231939]
--2024-01-27 05:21:08-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/block-mount_2024-01-22-08cd7083-1_aarch64_cortex-a53.ipk
Length: 31677 (31K) [application/octet-stream]
Saving to: ‘block-mount_2024-01-22-08cd7083-1_aarch64_cortex-a53.ipk’
block-mount_2024-01 100%[===================>] 30.93K 81.9KB/s in 0.4s
2024-01-27 05:21:11 (81.9 KB/s) - ‘block-mount_2024-01-22-08cd7083-1_aarch64_cortex-a53.ipk’ saved [31677/31677]
--2024-01-27 05:21:11-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/kmod-fs-exfat_5.15.147-1_aarch64_cortex-a53.ipk
Length: 38512 (38K) [application/octet-stream]
Saving to: ‘kmod-fs-exfat_5.15.147-1_aarch64_cortex-a53.ipk’
kmod-fs-exfat_5.15. 100%[===================>] 37.61K 77.7KB/s in 0.5s
2024-01-27 05:21:14 (77.7 KB/s) - ‘kmod-fs-exfat_5.15.147-1_aarch64_cortex-a53.ipk’ saved [38512/38512]
--2024-01-27 05:21:14-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/kmod-fs-ext4_5.15.147-1_aarch64_cortex-a53.ipk
Length: 997 [application/octet-stream]
Saving to: ‘kmod-fs-ext4_5.15.147-1_aarch64_cortex-a53.ipk’
kmod-fs-ext4_5.15.1 100%[===================>] 997 --.-KB/s in 0s
2024-01-27 05:21:16 (37.9 MB/s) - ‘kmod-fs-ext4_5.15.147-1_aarch64_cortex-a53.ipk’ saved [997/997]
--2024-01-27 05:21:16-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/kmod-fs-f2fs_5.15.147-1_aarch64_cortex-a53.ipk
Length: 983 [application/octet-stream]
Saving to: ‘kmod-fs-f2fs_5.15.147-1_aarch64_cortex-a53.ipk’
kmod-fs-f2fs_5.15.1 100%[===================>] 983 4.94KB/s in 0.2s
2024-01-27 05:21:19 (4.94 KB/s) - ‘kmod-fs-f2fs_5.15.147-1_aarch64_cortex-a53.ipk’ saved [983/983]
--2024-01-27 05:21:19-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/kmod-usb-storage-extras_5.15.147-1_aarch64_cortex-a53.ipk
Length: 31942 (31K) [application/octet-stream]
Saving to: ‘kmod-usb-storage-extras_5.15.147-1_aarch64_cortex-a53.ipk’
kmod-usb-storage-ex 100%[===================>] 31.19K 18.6KB/s in 1.7s
2024-01-27 05:21:23 (18.6 KB/s) - ‘kmod-usb-storage-extras_5.15.147-1_aarch64_cortex-a53.ipk’ saved [31942/31942]
--2024-01-27 05:21:23-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/kmod-usb-storage-uas_5.15.147-1_aarch64_cortex-a53.ipk
Length: 9909 (9.7K) [application/octet-stream]
Saving to: ‘kmod-usb-storage-uas_5.15.147-1_aarch64_cortex-a53.ipk’
kmod-usb-storage-ua 100%[===================>] 9.68K 32.8KB/s in 0.3s
2024-01-27 05:21:26 (32.8 KB/s) - ‘kmod-usb-storage-uas_5.15.147-1_aarch64_cortex-a53.ipk’ saved [9909/9909]
--2024-01-27 05:21:26-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/kmod-usb-storage_5.15.147-1_aarch64_cortex-a53.ipk
Length: 26150 (26K) [application/octet-stream]
Saving to: ‘kmod-usb-storage_5.15.147-1_aarch64_cortex-a53.ipk’
kmod-usb-storage_5. 100%[===================>] 25.54K 40.7KB/s in 0.6s
2024-01-27 05:21:29 (40.7 KB/s) - ‘kmod-usb-storage_5.15.147-1_aarch64_cortex-a53.ipk’ saved [26150/26150]
--2024-01-27 05:21:29-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/
owrt_packages_index 100%[===================>] 226.50K 100KB/s in 2.3s
2024-01-27 05:21:33 (100 KB/s) - ‘owrt_packages_index.html’ saved [231939/231939]
--2024-01-27 05:21:33-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/block-mount_2024-01-22-08cd7083-1_aarch64_cortex-a53.ipk
block-mount_2024-01 100%[===================>] 30.93K 76.0KB/s in 0.4s
2024-01-27 05:21:35 (76.0 KB/s) - ‘block-mount_2024-01-22-08cd7083-1_aarch64_cortex-a53.ipk’ saved [31677/31677]
--2024-01-27 05:21:35-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/kmod-fs-exfat_5.15.147-1_aarch64_cortex-a53.ipk
kmod-fs-exfat_5.15. 100%[===================>] 37.61K 22.0KB/s in 1.7s
2024-01-27 05:21:39 (22.0 KB/s) - ‘kmod-fs-exfat_5.15.147-1_aarch64_cortex-a53.ipk’ saved [38512/38512]
--2024-01-27 05:21:39-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/kmod-fs-ext4_5.15.147-1_aarch64_cortex-a53.ipk
2024-01-27 05:21:41 (26.8 MB/s) - ‘kmod-fs-ext4_5.15.147-1_aarch64_cortex-a53.ipk’ saved [997/997]
--2024-01-27 05:21:41-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/kmod-fs-f2fs_5.15.147-1_aarch64_cortex-a53.ipk
kmod-fs-f2fs_5.15.1 100%[===================>] 983 --.-KB/s in 0s
2024-01-27 05:21:43 (54.8 MB/s) - ‘kmod-fs-f2fs_5.15.147-1_aarch64_cortex-a53.ipk’ saved [983/983]
--2024-01-27 05:21:43-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/kmod-usb-storage-extras_5.15.147-1_aarch64_cortex-a53.ipk
kmod-usb-storage-ex 100%[===================>] 31.19K 43.3KB/s in 0.7s
2024-01-27 05:21:45 (43.3 KB/s) - ‘kmod-usb-storage-extras_5.15.147-1_aarch64_cortex-a53.ipk’ saved [31942/31942]
--2024-01-27 05:21:45-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/kmod-usb-storage-uas_5.15.147-1_aarch64_cortex-a53.ipk
kmod-usb-storage-ua 100%[===================>] 9.68K 55.3KB/s in 0.2s
2024-01-27 05:21:47 (55.3 KB/s) - ‘kmod-usb-storage-uas_5.15.147-1_aarch64_cortex-a53.ipk’ saved [9909/9909]
--2024-01-27 05:21:47-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/kmod-usb-storage_5.15.147-1_aarch64_cortex-a53.ipk
kmod-usb-storage_5. 100%[===================>] 25.54K 56.7KB/s in 0.5s
2024-01-27 05:21:50 (56.7 KB/s) - ‘kmod-usb-storage_5.15.147-1_aarch64_cortex-a53.ipk’ saved [26150/26150]
--2024-01-27 05:21:50-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/
owrt_packages_index 100%[===================>] 226.50K 110KB/s in 2.1s
2024-01-27 05:21:54 (110 KB/s) - ‘owrt_packages_index.html’ saved [231939/231939]
--2024-01-27 05:21:54-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/block-mount_2024-01-22-08cd7083-1_aarch64_cortex-a53.ipk
block-mount_2024-01 100%[===================>] 30.93K 78.2KB/s in 0.4s
2024-01-27 05:21:56 (78.2 KB/s) - ‘block-mount_2024-01-22-08cd7083-1_aarch64_cortex-a53.ipk’ saved [31677/31677]
--2024-01-27 05:21:56-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/kmod-fs-exfat_5.15.147-1_aarch64_cortex-a53.ipk
kmod-fs-exfat_5.15. 100%[===================>] 37.61K 92.4KB/s in 0.4s
2024-01-27 05:21:58 (92.4 KB/s) - ‘kmod-fs-exfat_5.15.147-1_aarch64_cortex-a53.ipk’ saved [38512/38512]
--2024-01-27 05:21:58-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/kmod-fs-ext4_5.15.147-1_aarch64_cortex-a53.ipk
2024-01-27 05:22:00 (39.2 MB/s) - ‘kmod-fs-ext4_5.15.147-1_aarch64_cortex-a53.ipk’ saved [997/997]
--2024-01-27 05:22:00-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/kmod-fs-f2fs_5.15.147-1_aarch64_cortex-a53.ipk
2024-01-27 05:22:02 (101 MB/s) - ‘kmod-fs-f2fs_5.15.147-1_aarch64_cortex-a53.ipk’ saved [983/983]
--2024-01-27 05:22:02-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/kmod-usb-storage-extras_5.15.147-1_aarch64_cortex-a53.ipk
kmod-usb-storage-ex 100%[===================>] 31.19K 19.6KB/s in 1.6s
2024-01-27 05:22:05 (19.6 KB/s) - ‘kmod-usb-storage-extras_5.15.147-1_aarch64_cortex-a53.ipk’ saved [31942/31942]
--2024-01-27 05:22:05-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/kmod-usb-storage-uas_5.15.147-1_aarch64_cortex-a53.ipk
kmod-usb-storage-ua 100%[===================>] 9.68K 29.2KB/s in 0.3s
2024-01-27 05:22:08 (29.2 KB/s) - ‘kmod-usb-storage-uas_5.15.147-1_aarch64_cortex-a53.ipk’ saved [9909/9909]
--2024-01-27 05:22:08-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/kmod-usb-storage_5.15.147-1_aarch64_cortex-a53.ipk
kmod-usb-storage_5. 100%[===================>] 25.54K 34.9KB/s in 0.7s
2024-01-27 05:22:11 (34.9 KB/s) - ‘kmod-usb-storage_5.15.147-1_aarch64_cortex-a53.ipk’ saved [26150/26150]
--2024-01-27 05:22:11-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/
owrt_packages_index 100%[===================>] 226.50K 97.5KB/s in 2.3s
2024-01-27 05:22:15 (97.5 KB/s) - ‘owrt_packages_index.html’ saved [231939/231939]
--2024-01-27 05:22:15-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/block-mount_2024-01-22-08cd7083-1_aarch64_cortex-a53.ipk
block-mount_2024-01 100%[===================>] 30.93K 75.5KB/s in 0.4s
2024-01-27 05:22:17 (75.5 KB/s) - ‘block-mount_2024-01-22-08cd7083-1_aarch64_cortex-a53.ipk’ saved [31677/31677]
--2024-01-27 05:22:17-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/kmod-fs-exfat_5.15.147-1_aarch64_cortex-a53.ipk
kmod-fs-exfat_5.15. 100%[===================>] 37.61K 93.1KB/s in 0.4s
2024-01-27 05:22:19 (93.1 KB/s) - ‘kmod-fs-exfat_5.15.147-1_aarch64_cortex-a53.ipk’ saved [38512/38512]
--2024-01-27 05:22:19-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/kmod-fs-ext4_5.15.147-1_aarch64_cortex-a53.ipk
2024-01-27 05:22:21 (37.0 MB/s) - ‘kmod-fs-ext4_5.15.147-1_aarch64_cortex-a53.ipk’ saved [997/997]
--2024-01-27 05:22:21-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/kmod-fs-f2fs_5.15.147-1_aarch64_cortex-a53.ipk
2024-01-27 05:22:23 (27.1 MB/s) - ‘kmod-fs-f2fs_5.15.147-1_aarch64_cortex-a53.ipk’ saved [983/983]
--2024-01-27 05:22:23-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/kmod-usb-storage-extras_5.15.147-1_aarch64_cortex-a53.ipk
kmod-usb-storage-ex 100%[===================>] 31.19K 22.3KB/s in 1.4s
2024-01-27 05:22:26 (22.3 KB/s) - ‘kmod-usb-storage-extras_5.15.147-1_aarch64_cortex-a53.ipk’ saved [31942/31942]
--2024-01-27 05:22:26-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/kmod-usb-storage-uas_5.15.147-1_aarch64_cortex-a53.ipk
kmod-usb-storage-ua 100%[===================>] 9.68K 26.4KB/s in 0.4s
2024-01-27 05:22:28 (26.4 KB/s) - ‘kmod-usb-storage-uas_5.15.147-1_aarch64_cortex-a53.ipk’ saved [9909/9909]
--2024-01-27 05:22:28-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/kmod-usb-storage_5.15.147-1_aarch64_cortex-a53.ipk
kmod-usb-storage_5. 100%[===================>] 25.54K 35.2KB/s in 0.7s
2024-01-27 05:22:31 (35.2 KB/s) - ‘kmod-usb-storage_5.15.147-1_aarch64_cortex-a53.ipk’ saved [26150/26150]
--2024-01-27 05:22:31-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/
owrt_packages_index 100%[===================>] 226.50K 89.0KB/s in 2.5s
2024-01-27 05:22:35 (89.0 KB/s) - ‘owrt_packages_index.html’ saved [231939/231939]
--2024-01-27 05:22:35-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/block-mount_2024-01-22-08cd7083-1_aarch64_cortex-a53.ipk
block-mount_2024-01 100%[===================>] 30.93K 74.7KB/s in 0.4s
2024-01-27 05:22:38 (74.7 KB/s) - ‘block-mount_2024-01-22-08cd7083-1_aarch64_cortex-a53.ipk’ saved [31677/31677]
--2024-01-27 05:22:38-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/kmod-fs-exfat_5.15.147-1_aarch64_cortex-a53.ipk
kmod-fs-exfat_5.15. 100%[===================>] 37.61K 96.4KB/s in 0.4s
2024-01-27 05:22:40 (96.4 KB/s) - ‘kmod-fs-exfat_5.15.147-1_aarch64_cortex-a53.ipk’ saved [38512/38512]
--2024-01-27 05:22:40-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/kmod-fs-ext4_5.15.147-1_aarch64_cortex-a53.ipk
2024-01-27 05:22:42 (26.7 MB/s) - ‘kmod-fs-ext4_5.15.147-1_aarch64_cortex-a53.ipk’ saved [997/997]
--2024-01-27 05:22:42-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/kmod-fs-f2fs_5.15.147-1_aarch64_cortex-a53.ipk
2024-01-27 05:22:44 (39.0 MB/s) - ‘kmod-fs-f2fs_5.15.147-1_aarch64_cortex-a53.ipk’ saved [983/983]
--2024-01-27 05:22:44-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/kmod-usb-storage-extras_5.15.147-1_aarch64_cortex-a53.ipk
kmod-usb-storage-ex 100%[===================>] 31.19K 21.4KB/s in 1.5s
2024-01-27 05:22:48 (21.4 KB/s) - ‘kmod-usb-storage-extras_5.15.147-1_aarch64_cortex-a53.ipk’ saved [31942/31942]
--2024-01-27 05:22:48-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/kmod-usb-storage-uas_5.15.147-1_aarch64_cortex-a53.ipk
kmod-usb-storage-ua 100%[===================>] 9.68K 35.2KB/s in 0.3s
2024-01-27 05:22:50 (35.2 KB/s) - ‘kmod-usb-storage-uas_5.15.147-1_aarch64_cortex-a53.ipk’ saved [9909/9909]
--2024-01-27 05:22:50-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/kmod-usb-storage_5.15.147-1_aarch64_cortex-a53.ipk
kmod-usb-storage_5. 100%[===================>] 25.54K 34.2KB/s in 0.7s
2024-01-27 05:22:52 (34.2 KB/s) - ‘kmod-usb-storage_5.15.147-1_aarch64_cortex-a53.ipk’ saved [26150/26150]
--2024-01-27 05:22:52-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/
owrt_packages_index 100%[===================>] 226.50K 92.3KB/s in 2.5s
2024-01-27 05:22:56 (92.3 KB/s) - ‘owrt_packages_index.html’ saved [231939/231939]
--2024-01-27 05:22:56-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/block-mount_2024-01-22-08cd7083-1_aarch64_cortex-a53.ipk
block-mount_2024-01 100%[===================>] 30.93K 68.2KB/s in 0.5s
2024-01-27 05:22:58 (68.2 KB/s) - ‘block-mount_2024-01-22-08cd7083-1_aarch64_cortex-a53.ipk’ saved [31677/31677]
--2024-01-27 05:22:58-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/kmod-fs-exfat_5.15.147-1_aarch64_cortex-a53.ipk
kmod-fs-exfat_5.15. 100%[===================>] 37.61K 91.5KB/s in 0.4s
2024-01-27 05:23:01 (91.5 KB/s) - ‘kmod-fs-exfat_5.15.147-1_aarch64_cortex-a53.ipk’ saved [38512/38512]
--2024-01-27 05:23:01-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/kmod-fs-ext4_5.15.147-1_aarch64_cortex-a53.ipk
2024-01-27 05:23:03 (37.9 MB/s) - ‘kmod-fs-ext4_5.15.147-1_aarch64_cortex-a53.ipk’ saved [997/997]
--2024-01-27 05:23:03-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/kmod-fs-f2fs_5.15.147-1_aarch64_cortex-a53.ipk
2024-01-27 05:23:05 (28.2 MB/s) - ‘kmod-fs-f2fs_5.15.147-1_aarch64_cortex-a53.ipk’ saved [983/983]
--2024-01-27 05:23:05-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/kmod-usb-storage-extras_5.15.147-1_aarch64_cortex-a53.ipk
kmod-usb-storage-ex 100%[===================>] 31.19K 21.5KB/s in 1.5s
2024-01-27 05:23:08 (21.5 KB/s) - ‘kmod-usb-storage-extras_5.15.147-1_aarch64_cortex-a53.ipk’ saved [31942/31942]
--2024-01-27 05:23:08-- https://downloads.openwrt.org/snapshots/targets/mediatek/filogic/packages/.....
That’s fine if the full output wouldn’t fit. You should now have a directory named owrt_usb_ipks with a mess of ipks in it on your Ubuntu machine. Can you pls post the output of ls -l within that directory fr the Terminal?
(This is just for my own piece of mind. We still have to get them installed in OWRT & I’m sure I’m going to have another error in that part, too.)
total of 116 files on file mananer GUI
angelina@angelina-Predator-PH315-51:~$ cd owrt_usb_ipks
angelina@angelina-Predator-PH315-51:~/owrt_usb_ipks$ ls -l
total 384
-rw-rw-r-- 1 angelina angelina 31677 Jan 27 00:05 block-mount_2024-01-22-08cd7083-1_aarch64_cortex-a53.ipk
-rw-rw-r-- 1 angelina angelina 38512 Jan 26 23:52 kmod-fs-exfat_5.15.147-1_aarch64_cortex-a53.ipk
-rw-rw-r-- 1 angelina angelina 997 Jan 26 23:52 kmod-fs-ext4_5.15.147-1_aarch64_cortex-a53.ipk
-rw-rw-r-- 1 angelina angelina 983 Jan 26 23:52 kmod-fs-f2fs_5.15.147-1_aarch64_cortex-a53.ipk
-rw-rw-r-- 1 angelina angelina 26150 Jan 27 00:02 kmod-usb-storage_5.15.147-1_aarch64_cortex-a53.ipk
-rw-rw-r-- 1 angelina angelina 31942 Jan 27 00:02 kmod-usb-storage-extras_5.15.147-1_aarch64_cortex-a53.ipk
-rw-rw-r-- 1 angelina angelina 9909 Jan 27 00:02 kmod-usb-storage-uas_5.15.147-1_aarch64_cortex-a53.ipk
-rw-rw-r-- 1 angelina angelina 231939 Jan 27 05:21 owrt_packages_index.html
drwxrwxr-x 3 angelina angelina 4096 Jan 27 05:21 owrt_usb_ipks
There should be 13 packages. I note there’s another owrt_usb_ipks dir within that owrt_usb_ipks dir (eg: ~/owrt_usb_ipks/owrt_usb_ipks.
Pls post the output of
ls ~/owrt_usb_ipks | wc -lls ~/owrt_usb_ipks/owrt_usb_ipks | wc -l
Cheers. I’m going to be a bit bold but the reason I want to script all this for you is so that you can help those you trust do the same. The Slate Plus, Slate AX, Beryl AX, Flint v1 are also able to run ‘stock’ OWRT 23.05 so the work you & I do to get LuCI on your Flint v2… maybe even v2RayA running, would be worth it for others.
(Please note I have no experience w/ v2RayA so I can’t make any guarantees there.)
yes theres like more than 7, 8 folders with same name inside each folder. along with some other files.
and yes thank you very much. i will spread the word
angelina@angelina-Predator-PH315-51:~/owrt_usb_ipks$ ls ~/owrt_usb_ipks | wc -l
9
angelina@angelina-Predator-PH315-51:~/owrt_usb_ipks$ ls ~/owrt_usb_ipks/owrt_usb_ipks | wc -l
9
Goddamnit; that’s another mistake I made. I told it to make a new dir for every package before downloading. That was stupid. Please delete the whole ~/owrt_usb_ipks dir & let’s try this updated script.
#!/bin/sh
# 2024-01-27-0051
# DESCRIPTION
# NOTE
# USAGE
# References:
exit 1
fi
usbutils
block-mount
libblkid
gdisk
parted
e2fsprogs
kmod-fs-ext4
kmod-fs-exfat
f2fs-tools
kmod-fs-f2fs"
mkdir owrt_usb_ipks
fi
for i in $IPKGS; do
done
done
fi
# as yet untested & prone to not work
# if [ "$1" = "install" ]; then
# for i in $IPKGS; do
# opkg install --force-reinstall --force-overwrite "$i"
# done
# fi
exit 0
total 380
-rw-rw-r-- 1 angelina angelina 231939 Jan 27 05:58 owrt_packages_index.html
Humm… still only 7 ipks of an expected 13. I gotta look at the OWRT repo for a moment to see what’s going on. Standby…
So I should have expected this. These are the ipks that didn’t get downloaded by the script:
usbutils
libblkid
gdisk
parted
e2fsprogs
f2fs-tools
I’m trying to pull those ipks from an incorrect repo/feed.
Goddamnit. I’m glad we caught this before we tried installing LuCI; that would have gone nowhere. Now I have to figure out how to determine what package/ipk is in what feed so it pulls from the proper one.
- Base: Index of /snapshots/packages/aarch64_cortex-a53/base/
- LuCI: Index of /snapshots/packages/aarch64_cortex-a53/luci/
- General: Index of /snapshots/packages/aarch64_cortex-a53/packages/
Now I have to retool the script to account for three very different sets of ipk feeds. You’ll have to leave this with me for today, tomorrow; I should have something sorted out – or close to it – by that time.
If you don’t want to wait you could manually download the required ipks but I’d prefer you & I get a set of scripts working so you can give them to others. It’s your call to make, of course.
I’m on the forum near daily but tomorrow I think I’ll spend some solid time working this out.
Thank you very much. Yes we can continue tomorrow. its also 10am here and i stayed up all night. I better get some sleep too. and you need some rest too
Thanks again for your help.
we will continue tomorrow.
I appreciate your hard work x
It’s 0132 here. To be continued. Good nite.
Wow, you a genius
but be careful don’t make a brick router ![]()
It’s nearly impossible to brick GL devices by software.
As long as there is uboot (no matter if it’s the GL or OpenWrt one) you can always take it back to life.
At this point it is running stock OpenWRT (snapshot). All the things being done now, is just getting packages to download elsewhere and get them installed on the router as the normal package repo’s are inaccessible. Chances of bricking fairly much small at this point.
bring.fringe18, the reason the router stayed at 192.168.8.1 is because sky_corridors did keep the settings. I wouldn’t recommend doing that when going from gl-inet to stock firmwares, but it appears to be not a real issue. However it could be that something might be a bit messed up.
I would recommend checking if DNS might be misconfigured due to keeping settings.
Yeah; I know. It was a Sysupgrade; not a proper flash via U-boot. I was going to bring it up w/ OP that I’d really consider reflashing according to a U-boot image/procedure if only to clear the cruft.
Krist, I need to go to bed. G’nite/g’morning. Whatever.
# TODO: have OP chk DNS when LuCI online.
