Here is “ If this option is enabled, services on routers that usually require the use of a real IP will USE VPN. Including GoodCloud, DDNS, rtty.” In documentation “will not use”. Where is correct?
- if i enable this option will adguard use vpn? after all, dns requests from adguard already go through a vpn, even if this option is disabled
