so I’ve been using a protonvpn.ovpn (for android clients) which has been working since the original slate came out and it has also worked on b1300, mv1000 ar750,ar150, mango. when I use it in the AX betas so far it makes a connection and works for connectivity for the users but you cannot disable or delete it because it is currently in use. upon intall you enable it in the vpn dashboard but then the disable/enable button disappears and “setup now” is replaced and yes the setting survives reboots and adding another vpn.ovpn to the group or creating anthother new group and entry does not stop the issue. it’s locked, running and cant be removed other than a firmware reset.
ovpn file has multiple server addresses and ports along with
server-poll-timeout 20
remote-random
resolv-retry infinite
perhaps you guys are not handling this correctly unless it is being confused inside the gli vpn group.
update:
I commented out
#server-poll-timeout 20
#remote-random
#resolv-retry infinite
and deleted all but the first server adress in /etc/openvpn/profiles/proton.ovpn
and also deleted all the additional servers and left one in /etc/config/ovpnclient.
that solved the problem. you may wish to check for those parameters when considering groups.
client
dev tun
proto udp
remote 185.159.157.104 5060
remote 185.159.157.104 443
remote 185.159.157.104 4569
remote 185.159.157.104 1194
remote 185.159.157.161 1194
remote 185.159.157.161 5060
remote 185.159.157.161 4569
remote 185.159.157.161 443
remote 185.159.157.161 80
remote 185.159.157.104 80
remote-random
nobind
# The following setting is only needed for old OpenVPN clients compatibility. New clients
# automatically negotiate the optimal cipher.
cipher AES-256-CBC
auth SHA512
verb 3
setenv CLIENT_CERT 0
tun-mtu 1500
tun-mtu-extra 32
mssfix 1450
persist-key
persist-tun
reneg-sec 0
remote-cert-tls server
auth-user-pass
pull
fast-io
<ca>
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----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</ca>
key-direction 1
<tls-auth>
# 2048 bit OpenVPN static key
-----BEGIN OpenVPN Static key V1-----
6acef03f62675b4b1bbd03e53b187727
423cea742242106cb2916a8a4c829756
3d22c7e5cef430b1103c6f66eb1fc5b3
75a672f158e2e2e936c3faa48b035a6d
e17beaac23b5f03b10b868d53d03521d
8ba115059da777a60cbfd7b2c9c57472
78a15b8f6e68a3ef7fd583ec9f398c8b
d4735dab40cbd1e3c62a822e97489186
c30a0b48c7c38ea32ceb056d3fa5a710
e10ccc7a0ddb363b08c3d2777a3395e1
0c0b6080f56309192ab5aacd4b45f55d
a61fc77af39bd81a19218a79762c3386
2df55785075f37d8c71dc8a42097ee43
344739a0dd48d03025b0450cf1fb5e8c
aeb893d9a96d1f15519bb3c4dcb40ee3
16672ea16c012664f8a9f11255518deb
-----END OpenVPN Static key V1-----
</tls-auth>
Seems you just met a bug that the firmware cannot deal with. I will use your opvn to have a check.
I used your ovpn. Upload and made a connection.
Then I stop it and go to ovpn management and I can delete the group.
Can you let me know how I can replicate your issue?
after creating the entry you must enter the username and password and make a connection. you would have a green dot in front of proton under name which you don’t in the picture. are you saying you made a succesful vpn connection from a paid user account and the connection worked? (just incase you have a free account becuae there are specific servers for those)
I can reproduce it 100% of the time because a connection must be made to reproduce. I believe you so now i’m thinking i hit the lottery by connecting to defective vpn servers at proton 100% on the random retry roulette table? i will try my luck again.
let me give you the whole file with begining comments
# Copyright (c) 2016-2020 Proton Technologies AG (Switzerland)
# Email: contact@protonvpn.com
# The MIT License (MIT)
# Permission is hereby granted, free of charge, to any person obtaining a copy
# of this software and associated documentation files (the "Software"), to deal
# in the Software without restriction, including without limitation the rights
# to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
# copies of the Software, and to permit persons to whom the Software is
# furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in all
# copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
# AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR # OTHERWISE, ARISING
# FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS
# IN THE SOFTWARE.
# If you want to enable the ProtonVPN ad blocker (NetShield):
# Use: "O8_iQahXY8qipgWDyugt0mdG+f1" as username to enable anti-malware filtering
# Use: "O8_iQahXY8qipgWDyugt0mdG+f2" as username to additionally enable ad-blocking filtering.
client
dev tun
proto udp
remote 185.159.157.86 5060
remote 185.159.157.116 443
remote 185.159.157.29 1194
remote 185.159.157.173 4569
remote 185.159.157.123 5060
remote 185.159.157.144 80
remote 185.159.157.174 4569
remote 185.159.157.158 1194
remote 185.159.157.144 5060
remote 185.159.157.86 1194
remote 185.159.157.116 5060
remote 185.159.157.99 80
remote 185.159.157.99 1194
remote 185.159.157.123 443
remote 185.159.157.170 80
remote 185.159.157.123 80
remote 185.159.157.170 4569
remote 185.159.157.99 5060
remote 185.159.157.29 80
remote 185.159.157.175 443
remote 185.159.157.174 1194
remote 185.159.157.160 1194
remote 185.159.157.116 80
remote 185.159.157.29 4569
remote 185.159.157.158 5060
remote 185.159.157.158 80
remote 185.159.157.86 4569
remote 185.159.157.86 80
remote 185.159.157.99 443
remote 185.159.157.170 1194
remote 185.159.157.170 5060
remote 185.159.157.123 1194
remote 185.159.157.170 443
remote 185.159.157.175 80
remote 185.159.157.173 443
remote 185.159.157.160 4569
remote 185.159.157.173 80
remote 185.159.157.29 443
remote 185.159.157.99 4569
remote 185.159.157.144 1194
remote 185.159.157.160 80
remote 185.159.157.158 443
remote 185.159.157.123 4569
remote 185.159.157.116 1194
remote 185.159.157.173 1194
remote 185.159.157.174 443
remote 185.159.157.173 5060
remote 185.159.157.160 443
remote 185.159.157.175 5060
remote 185.159.157.174 5060
remote 185.159.157.144 443
remote 185.159.157.174 80
remote 185.159.157.29 5060
remote 185.159.157.116 4569
remote 185.159.157.86 443
remote 185.159.157.175 1194
remote 185.159.157.160 5060
remote 185.159.157.144 4569
remote 185.159.157.158 4569
remote 185.159.157.175 4569
remote-random
nobind
cipher AES-256-CBC
auth SHA512
verb 3
tun-mtu 1500
tun-mtu-extra 32
mssfix 1450
persist-key
persist-tun
reneg-sec 0
auth-user-pass
pull
fast-io
<ca>
A1gTTlpi7A==
</ca>
key-direction 1
<tls-auth>
</tls-auth>
