Vpn not connecting
Unable to connect to vpn server. I matched configs on both server and client. Attaching pics from client.
Please check How to troubleshoot WireGuard
I did check. All settings seems to be correct.
So please share your config then (minus the keys)
Do both routers use the same network (like 192.168.8.1?)
Yes. Primary router ATT is 192.168.1.254 and brume router is 1.67.
That does not work as described here:
https://forum.gl-inet.com/t/how-to-troubleshoot-wireguard/42502#this-doesnt-work-5
