Vpn policies 4.7.4 disney plus
Hello, i was hoping to get som help,
I run vpn on the router and I want to have it on all the time and just use vpn policy that specific devices do not use vpn, like the Android tv so disney plus works, it worked before 4.7 update and after i stopped working AT all, now with 4.7.4 i can log in but i get error 42 or cant start streaming anything, error 42 is that i am unable to connect to disney
Flint 2 router
Vpn ovpn.com with a swedish vpn server
I live in sweden
You can use the "VPN Policy Based on the Client Device" mode and select "Use VPN", add the MAC of that TV, and then the TV can go to the VPN specifically.
Also, you need to select a VPN server that can access Disney. (Please confirm it with your VPN provider)
I use the vpn policy already and have set the tv to "do not use vpn" via Mac
And when i dont use the vpn as said over i get an message that i dont have a internet connection in The disney app on the tv.
This worked before V4.7 one the router
I should be able to use the vpn with disney according to the vpn provider with the vpn but i have not gotten this to work
How did you update from 4.7 to 4.7.4?
Clean install or simply click Update?
Stop the Disney app and clear the cache?
Different server from the VPN provider?
Which VPN provider?
Did you use the VPN provider's DNS addresses or others?
Hi i did update no Clean install,
I have cleared cache an data of the disney app
I have tested diffrent servers from the vpn provider
Vpn provider ovpn.com
I use the vpn provider dns
You can use plugin tcpdump to capture packets and confirm what the domain name or IP of the Disney APP video streaming of TV used is?
Then under the current router configuration, execute traceroute www.disney.com on router or client PC tracert www.disney.com on CMD, to check if it goes to WAN or goes to VPN?
I had a similar problem, but with a different VPN provider. After a clean install, no more problems.
I'm currently being told I have a DNS leak. Which is very strange since everything is IPV6 disabled.
Hi i will test to do a Clean install first, is it just to do a reset you mean? In The control panel?
You did it here:
But this is the method I'm talking about. To be precise, a completely new flash of the router. Please keep in mind, however, that afterward, all settings will be lost, but you'll have a clean firmware install without any legacy issues.
Make the settings on your PC according to your operating system. Unplug everything from the router (including the power). Connect the LAN cable to port 1 and then to the PC. Hold the reset button and reconnect the power, continuing to hold the button until the LED turns white.
!!!! All settings will be deleted afterward, and you'll have to set everything up again!!!!
i did a full reset, i did work as it should, i did notice that the DNS from my VPN provider did not work with disney, so i changed them to cloudflare and it worked again :slight_smile:
thanks for the help
