I’ve set up some VPN policies on my Mango based on target IP/domains (basically netflix traffic) and wireguard.
Everything seems to work properly from LAN clients perspective.
However, if I jump via SSH on the router, I noticed that all traffic from there use the wgclient interface.
This is my routing table:
estination Gateway Genmask Flags Metric Ref Use Iface
default * 128.0.0.0 U 0 0 0 wgclient
default 192.168.1.1 0.0.0.0 UG 10 0 0 eth0.2
128.0.0.0 * 128.0.0.0 U 0 0 0 wgclient
192.168.1.0 * 255.255.255.0 U 10 0 0 eth0.2
192.168.8.0 * 255.255.255.0 U 0 0 0 br-lan
A check on the route it takes for 1.1.1.1:
root@GL-MT300N-V2:~# ip route get 1.1.1.1
1.1.1.1 dev wgclient src 10.1.242.180 uid 0
A check on my external ip reports the Wireguard endpoint instead of my isp:
root@GL-MT300N-V2:~# curl https://ipinfo.io/ip
188.213.34.xxx
What should I do to instradate traffic from router accordingly to VPN policies I’ve set?
