I want most devices to use the VPN, but some devices dont work well and some sites dont work well. I want to exclude those devices, and also those sites as well (so for all devices). By treating the list as an ‘exclusion’ list, I don’t see a conflict (one mode versus the other). Why not add mac address and sites to the list. example …
“Do not use VPN for the items in the list”
f8:54:b8:00:11:22 (mac device)
somehost com (web site)
meaning everything on the mac address device will skip the vpn, and everything else also will skip the vpn for the website in question (on those other devices). simple enough?
“include” would be the inverse, include anything that qualifies by device or by web address. current lists work the same, just using all mac or all website, with no other changes needed.
Is there some way of doing this, the current firmware/software only uses one-or-the-other-type-filter.
Also noted to make this useful (another post, that wildcards don’t work, so some sites are still problematic in that regard and need that as well, I assumed example, netflix com would mean *.netflix com?? but it doesn’t, so wildcards would solve that)
