puli on 3.215. Connected via wireguard. VPN works.
Policies guest network not on vpn works as expected.
domain/ip → do not use →
does not
tried
rebooting router after settings, rebooting PC, clearing DNS cache etc.
does not
tried
How did you set? Can you give a screenshot? and how do you verifiy?
speedcheck.org is supposed to show local ip and provider but instead shows vpn ip and provider i.e. it is under vpn
apply button was pressed - > no joy
vpn restarted → no joy
router rebooted → no joy
router hard on/off → no joy
Cache cleared / browser restarted / computer restarted → no joy
different computer used → no joy
problem exists for both wireguard and openvpn configurations
tried different domains of sites that expose and report ip/provider - same problems so not site related
Let me check tomorrow
