I have AR 750 Creta and B 1300 and I’m very satisfied about them.
My question is:
why is not possible te combined use of "use vpn for and “do not use vpn for”?
If these functions were possible together I could use gl inet router as main router of my lan more easily…
@alzhao
In “do not use vpn for” section are ip or domains only destinations while mac addresses sources, right?
I ask you because I’ve tried to insert an ip of a client 192.168.8.x but the client has contineued to go out through VPN.
Considering that Domain/ip based and mac address based combined policies is too complicated to define It would be possible, at least, to have sources ip and destinations ip/domains combined policy?
Yes 192.168.8.11 goes to YouTube not via vpn.
My vpn policies are:
Use vpn for all process and not for guest lan. Do not use vpn for a list of domains (e.g.netflix, youtube) and ip (my main lan 192.168.1.x) and it works.
I would like to be able to maintain this policy and to add clients IPs of 192.168.8.x (b 1300 lan) that never have to go through vpn.
This possibility would allow me to use b 1300 as main router of my lan; now instead clients that never go through vpn have to stay in the lan of main router.
Is it possible?
Thanks
