Hi there,
I am using a wireguard vpn and enabled the VPN Policies feature.
My idea was to use the VPN for everything, except a few geo restricted and streaming sites, but this is not working as intended, for subdomains…
For example, I want to bypass the VPN for netflix.com and a few other domains, such as nflxso.net or nflxvideo.net which are critical to play the media. However, netflix specifically uses randomized subdomains of these domains, so when I add the domains above to the exclusions lists, it does not work for it’s subdomains and netflix blocks me.
I would like to add the root domain, and then skip the vpn for that domain and all subdomains.
Of course, ideally it should support wildcards, but that not being possible I would at least be happy if I can skip all subdomains for the root domain that I added.
Is there any possibility to do this, either via web interface or command line?
Thanks
