Hi is correct this setup to avoid that email servers are routed through VPN? If I a add another row with “ebay.it | amazon.it” those site dont’use VPN also?
Cheers R
Cheers R
I could only enter one domain per line. Using | to divide entries always gives me a parameter error.
Hi, with firmware 3.100 do policies work?
I have add only one line but the site is irraggiungibile, the browser stuck on “waiting for host resolution” message.
Cheers R.
Maybe it is only problem of specific domain. Can you try other domains?
