Hello, I do use the flint with wireguard to watch geo locked contect, I have been unfortunate in getting a good way to determine domains used in various apps, anyone have an idea of a good way to get domains/ip of apps
You can determine domains:
Check your IP address by using whatismyipaddress.com
Check your dns leak by using dnsleaktest.com
That should be the case for all clients. But apps may save your previous location somewhere.
