VPN policy by domain or IP address is not working.
Currently running Wireguard Client. I have a list of IP addresses that I do not want to go through the VPN tunnel. One of the IP addresses listed is the static IP address of my PS5. However, I am still seeing the IP address of my VPN client after running a check. I have also tried placing the IP address of my Mac Studio outside of the VPN tunnel and upon going to whatismyipaddress.com, I am still seeing the VPN client IP address here as well.
What am I missing here? Is there a way to run a VPN policy based on IP address while also running a policy based on what the client device is? It seems that these are in two separate and uncombinable options.
Thank you for the fast reply, @admon. Could I use the option titled Customize Routing Rules? I don’t see an option to do any further customization after I’ve selected this option.
I’d block the console via its MAC (GL GUI → Clients → $MAC) given you can’t do by IP via VPN Policy Base On The Target Domain Or IP → [ Use / Do Not Use ]; it’s a similar option for VPN Policy Base On The Client Device.
