VPN Policy issue when Block Non-VPN Traffic
I have an issue with Flint 2.
On VPN Dashboard if I Modify Proxy Mode -> VPN Policy Based on the VLAN and select Private Enable VPN and Guest Disable VPN. Then on VPN Dashboard -> Global Options I Block Non-VPN Traffic then all the traffic from Guest network will be blocked.
I think here this option should be available based on which VLAN the VPN is Enabled.
If I enable VPN for Private VLAN then Block Non-VPN Traffic just for Private VLAN and not for both Guest and Private.
Anyone know how can I sort it out?
Thanks
Thank you, we are aware of this issue and R&D will improve it in v4.8 firmware.
