VPN Provider:Witopia Not Listed
My VPN provider is not one of those listed in the Guide (Witopia, aka PersonalVPN). They have an app that greatly simplifies connecting a VPN on an end device, but I see no way to leverage that app on this router. Can a VPN config file be manually edited/created on this router? If so, how? Or do I need to obtain a configuration file from Witopia, copy it to the router somehow, and then install it?
download the OpenVPN Config file from your Dashboard …
On the Website under Support you find FAQ and use the FAQ for Android an create your file and upload then on your Router (via Webinterface)
BR
Thank you much. Turns out I already had a file on my router from a previous setup session; I just wasn’t familiar with the dbl-ended arrow button. All’s good now.
