VPN question
My VPN provider only supports IPv4. How can I block IPv6 to prevent my IPv6 leak?
Can you please provide me with commands/scripts?
Log in into LuCi then Network → Interfaces → Devices and click on each Configure for each listed device and then uncheck Enable IPv6
I need to exactly block not disable. It is unchecked. I need to be more sure that there will no my real IP leak.
P.S: Is there any way to block WebRTC directly on router?
If your WAN interface does not have an IPv6 assigned then there won’t be any leaks !
