I am on the road to “work from home” in another country. At the minute I am based in the UK.
I want to purchase a VPN router so my IP location stays in the UK. Atm I am looking at Beryl AX GL-MT3000 router. With openVPN and WireGuard.
The system I am working from is a desktop PC which uses a wired internet cable, no Wi-Fi.
What is the better option (easier)? To set up two routers, one as a VPN server to a network in the UK and another router in the country I am going to as a client and connect the client one to my desktop. Or buy the above mentioned router and use it as a VPN aka taking it with me?
Whats the process behind both ?
< snicker > I love how many people are looking to do clandestine remote working now that the COVID ‘lockdowns’ are all but lifted. It’s good stuff.
@Arralian , that’s a great choice for a GL device but don’t forget the Slate AX outperforms the Beryl AX in both WireGuard & OpenVPN. You’re going to want WireGuard as your VPN tunnel tech. if you can.
More on topic: here’s a couple of threads related to your goals:
Run the WireGuard Server on this router. Then generate the client profile and export it.
But you need to make sure it has a public IP available. This device has a public IP or you can set up forwarding on the ISP router.
Yes, you just need to import this client profile in WireGuar Client and run it.
Hey, were you ever able to set up your router? Right now I only have one, I already set up the OpenVPN client but I am not sure what to do next. I work from home in the US but traveling abroad and I am a bit confused on how to properly set up my Beryl router to reflect either my home IP or an USA IP address from my personal third party vpn client.
