I want to setup a permanent VPN connection using OpenVPN or Wireguard. The local clients will be connected via LAN cable to the VPN router. However, the WAN connection to the internet router needs to be established via Wifi.
Is this something that the GL.Inet routers support? (and which one then to chose)
Thanks!
Here you are
Recommendation of the router is based on your needs. So you might need to add a few details about how many LAN ports, etc. etc.
Thanks!
Well, high throughput on the VPN connection would be the most important aspect, incl the wifi network. (Internet is 2 Gbit cable.)
It does not need to be portable. 2 clients/ports only.
None of them will provide more than 900 Mbps all in all (Flint 2) using WireGuard - but only as client. Server might be less.
See: Product Comparison - GL.iNet
OK, then I will go with the Flint 2. Thanks!
