hi - I would like to use the B1300 router as vpn server - only for 2 w10-lan-clients.
is it possible to use the b1300 router without dhcp and without wifi. the fritzbox is doing the dhcp and the clients have a network address e.g. 192.168.1.36 - the dhcp should stay on the fritzbox (192.168.1.1) - this is important because of my smarthome network with about 200 clients (they should not use the vpn-tunnel)
the b1300 is on 192.168.8.1 - like the standard settings
ist it possible to configure the client (192.168.1.36) to use the vpn tunnel for internet and still have a connection to the 192.168.1.0/24 net - can I configure the b1300 to do this.
I do not have experience in network settings - maybe somebody could help me
you are right - I configured the vpn connection over vpn-client. this is working over wifi connections. but at the moment the b1300 is switched off - because of the 2 dhcp servers
my questions are:
how to disable the dhcp server on the b1300 ?
how to configure the win10 lan client - should the client get an fixed ip address in the range of the b1300. eg. 192.168.8.10 and the gateway 192.168.8.1 ?
do I have to add a route on b1300 to the 192.168.1.0/24 net ?
if the client defined gateway is 192.168.8.1. - does the b1300 knows, that it should route over vpn into the internet (I have tried this - is not working) - I have read somewhere that I have to use the b1300 dhcp server in order to get a vpn connection because the vpn connection is only working if dhcp is kowing the client-pc
