VPN taking over DNS from AdGuard Home
I have a Flint 2 Router running Stable 4.8.3.
I have NordVPN via Wireguard, Adguard Home, and Tailscale all installed.
I have a Linux Mint exit node connected via eth.
My goal is to have all portable devices (iphone, ipad, macbook) connected to the exit node 24/7 and route all traffic through the AdGuard Home filters and selected upstream DNS, then through NordVPN.
What is happening right now when i use the exit node is that NordVPN’s DNS servers are taking over the DNS traffic and im missing out on the AdGuard filters. When I use something like Connection check | Mullvad VPN instead of it confirming that i am using Mullvad DNS(this is set as the sole upstream DNS in Adguard Home) i get DNS servers that are for NordVPN.
When I do NOT use the exit node. The checker confirms im using Mullvad DNS.
So i figure it HAS to be an issue with Tailscale settings but if im being honest, I don’t know enough to be sure of anything.
MagicDNS is enabled, and my Global Nameserver is set to 194.242.2.5 with “Override DNS Servers” toggled on & the nameserver set to “Use with exit node”
Im not sure if this is a Glinet router issue OR a Tailscale issue hence the cross post.
Any guidance is greatly appreciated!
NordVPN redirects all unencrypted DNS traffic to their own infrastructure, so please make sure you’re using encrypted DNS in the AdGuard Home upstream DNS configuration. You can refer to the list provided by Mullvad DNS here:
Additionally, make sure “Allow Custom DNS to Override VPN DNS” is enabled under Admin Panel → Network → DNS, so that AdGuard Home can take over DNS requests when the VPN is active.
