VPN won’t connect (2x GL-A1300 to get a home IP address)
Hi everyone,
I bought 2x GL-A1300 Slate Plus to use my home IP address on my laptop while abroad.
The first GL-A1300 is connected to my Vodafone cable router via LAN. I enabled DynDNS on the GL-A1300, set up an OpenVPN server, and exported the config/certificate. The OpenVPN server is shown as green.
The second GL-A1300 was configured as a VPN client, and I uploaded the server's config/certificate. Unfortunately, after starting it, the status stays yellow and I get the following error messages in the log file:
  • No server certificate verification method has been enabled.
  • the current --script-security setting may allow this configuration to call user-defined scripts
  • Cannot resolve host address: rl69dab.glddns.com:1194 (Name does not resolve)
  • Could not determine IPv4/IPv6 protocol
The GL-A1300 VPN client is connected to the internet through my phone's hotspot. But when I connect my laptop to the GL-1300 VPN client, I can't access the internet. When I connect to the GL-A1300 VPN server (which is connected to the router), I do get internet access.
I tried changing the DNS settings on both the server and client from automatic to manual and entering 8.8.8.8, but that didn't change anything.
I also assigned a static IP address to the GL-A1300 that's connected to the router. Unfortunately, there doesn't seem to be much I can configure on the Vodafone cable router. I also briefly disabled the firewall on the cable router, thinking perhaps the VPN port was being blocked, but that made no difference.
What am I doing wrong, or what am I overlooking? I'd be really grateful if someone could help me out!
Best wishes to the community
We noticed that you have already reached out to us by email regarding this issue.
Please continue working with our support team through the ticket system so we can assist you more effectively.
This post will remain open in case other users wish to share additional suggestions.
